- AlessandroEmm
8 months 2 weeks ago - 8 months 2 weeks ago #343188
by AlessandroEmm
Replied by AlessandroEmm on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
I made some progress, SPI wasnt likely working properly before, as I had chosen PB9 for the pru-reset. Turns out PB9's timer is already occupied so no PWM. I change to PB15 which is usable for PWM and now i'm getting a
When trying to unlock the e-Stop.
Bad SPI payload = c8c2e8c2
Last edit: 8 months 2 weeks ago by AlessandroEmm.
- AlessandroEmm
8 months 1 week ago #343193
by AlessandroEmm
I just realised I still had SPI_clk_div set to 16, after setting it back to 32 or 64, the errors are gone, but i'm at square one again, no error on e-stop deactivate.
8 months 1 week ago #343208
by cakeslob
Replied by cakeslob on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
the fact that you get a bad spi payload is good, keep it at 32 probably
This may sound forward of me, but how long is your cable?
- AlessandroEmm
8 months 1 week ago - 8 months 1 week ago #343228
by AlessandroEmm
Last edit: 8 months 1 week ago by AlessandroEmm.
8 months 1 week ago - 8 months 1 week ago #343283
by cakeslob
those wires look too long and too loose. you will need to shorten them for sure and tighten them up a big
shorter is better, keep it as short as possible
edit do you mean 8inches and not 8cm? 8cm is the length of the rpi board
Last edit: 8 months 1 week ago by cakeslob.
- AlessandroEmm
8 months 1 week ago - 8 months 1 week ago #343354
by AlessandroEmm
They were actually 10cm, now they are closer to 4.
Unfortunately wasnt the (root) cause of my issues.
Time to create page: 1.309 seconds
