Dell 780 sff E8400 4gb ram usability
22 Sep 2021 04:17 - 22 Sep 2021 04:19 #221324 by Joco
Replied by Joco on topic Dell 780 sff E8400 4gb ram usability
From what I have read anything sub 70k jitter is fine with ethernet cards.   So if you are clocking comfortably under 50k on jitter I would have thought you would be fine.
The next think to check is you ping time from the machine to the ethernet mesa card.   If you are on intel or realtec nics it should be pretty good.  Broadcom is a problem.  You have to work hard to tune that to perform with a tight enough network latency.
Last edit: 22 Sep 2021 04:19 by Joco.
