Remora - NVEM / EC300 / EC500
- beauxnez
- Thank you received: 10
10 Feb 2025 04:13 #321135
by beauxnez
Replied by beauxnez on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
thanks but I'm really sorry but I don't know what I'm doing (it's Chinese to me)
I see in the qtplasmac_comp.hal file the line "net plasmac:scribe-start spindle.1.on => plasmac.scribe-start"
should I copy it into my NVEM.hal file?
- cakeslob
- Thank you received: 275
10 Feb 2025 05:06 #321137
by cakeslob
add this to [TRAJ] in your ini file
SPINDLES = 3
- beauxnez
10 Feb 2025 05:18 - 10 Feb 2025 05:19 #321138
by beauxnez
same error when modifying the .ini file
Last edit: 10 Feb 2025 05:19 by beauxnez.
- cakeslob
11 Feb 2025 00:59 - 11 Feb 2025 01:01 #321199
by cakeslob
alright in hal, change this line to this
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS[TRAJ]SPINDLES
Last edit: 11 Feb 2025 01:01 by cakeslob.
- beauxnez
11 Feb 2025 17:51 - 11 Feb 2025 17:52 #321252
by beauxnez
still an error
Debug file information:
Note: Using POSIX realtime
MOTION: num_joints is 33, must be between 1 and 16
motmod: rtapi_app_main: Operation not permitted (-1)
./NVEM.hal:5: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:5: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:5: insmod for motmod failed, returned -1
10762
Stopping realtime threads
Unloading hal components
Last edit: 11 Feb 2025 17:52 by beauxnez.
- beauxnez
11 Feb 2025 17:53 - 11 Feb 2025 18:43 #321253
by beauxnez
Last edit: 11 Feb 2025 18:43 by beauxnez.
- beauxnez
11 Feb 2025 18:32 - 11 Feb 2025 19:00 #321261
by beauxnez
the pin number on the config.txt file is "P4_17"
"Thread": "Servo",
"Type": "Digital Pin",
"Comment": "XIN",
"Pin": "P4_17",
"Mode": "Input",
"Data Bit": 17,
"Invert": "True"
I have to write like this in the .hal file?
# ---X Axis Inputs---
# X Home Prox
net XHome joint.0.home-sw-in <= remora.input.17
"Thread": "Servo",
"Comment": "XIN",
"Pin": "P4_17",
"Mode": "Input",
"Data Bit": 17,
"Invert": "True"
# X Home Prox
Last edit: 11 Feb 2025 19:00 by beauxnez.
- cakeslob
12 Feb 2025 04:54 #321318
by cakeslob
yeah, did you fix the other 2? the first one is you didnt install the nvmpg component, and the second one is the halfile for that usb pendant isnt present
but yes thats how you connect the x thing probably
- beauxnez
12 Feb 2025 18:56 - 12 Feb 2025 19:07 #321368
by beauxnez
I installed the nvmpg component but I still have the same error with the command
sudo halcompile --install nvmpg.c.
I have a Linux Mint LMDE 6 Faye version, it may be too old?
Last edit: 12 Feb 2025 19:07 by beauxnez.
- cakeslob
12 Feb 2025 19:51 #321372
by cakeslob
I think I misread that first error,
remove the xhc-whb04b-6.hal
[HAL]
HALFILE = NVEM.hal
HALFILE = qtplasmac_comp.hal
HALFILE = xhc-whb04b-6.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal.
Time to create page: 0.241 seconds
