Remora - NVEM / EC300 / EC500
- Murphy
- Thank you received: 5
12 May 2025 17:05 #328291
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
What does it do when you try adjust the speed? Is it a VFD you are using? What is the speed input to the vfd pwm or 0-10v analog. Have you the VFD wired correctly ?
- Spyderbreath
- Thank you received: 9
12 May 2025 18:06 #328297
by Spyderbreath
To answer your questions in order -
1. Nothing happens when I try to adjust the speed. Whether I issue an M3 S100 or M3 S15000, the speed is the same. VFD panel reports 3500 rpm, or at least I think it's RPM, anyway, no change.
2. Yes, VFD
3 The input is suppose to be 0-10v and if the translator on my phone is correct that is connected to the AI1 (0-10v analog signal input) on VFD
3. As far as I can tell.... There are only 3 wires, COM, AI1 for the 0-10v analog and X1 that connects to spindle out1 (spindle-cw)
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
OK, This is a Merckweir MK300 VFD that was installed from the factory. As par for the course with this machine, the unit is an old out of production version. All this that I am trying to do now is to salvage the purchase of this mill after taking a giga hose job and losing over $3k.What does it do when you try adjust the speed? Is it a VFD you are using? What is the speed input to the vfd pwm or 0-10v analog. Have you the VFD wired correctly ?
2. Yes, VFD
- Murphy
12 May 2025 18:17 - 12 May 2025 18:18 #328298
by Murphy
Measure the input voltage at the VFD it's probably at 10v constant ?
Yes you can also hook up outputs for FWD and REV.
Last edit: 12 May 2025 18:18 by Murphy.
- Spyderbreath
12 May 2025 19:05 #328302
by Spyderbreath
Actually, no. Spindle 'ON' shows 0v between COM and AI1.
- cakeslob
- Thank you received: 275
12 May 2025 19:22 #328305
by cakeslob
sorry spyder, i had a provision set up so you could do everything from ini file. just sawp these 2 lines, uncomment the one
for the outputs, yeah you need to change them to whatever your outputs are
#setp scale-rpm.gain 0.02 # 100/ rpm (5000) = .02
setp scale-rpm.gain [SPINDLE_0]RPM_GAIN # 100/ rpm (5000) = .02
- cakeslob
12 May 2025 19:33 #328307
by cakeslob
Thats what we needed to see, but this is somewhat expected by the reading from the halscope of SP.0 . alright, well this can be 2 fold. either the RT1052 firmware is doing it, or the analog circuit is messing up. It doesnt show up on mine because Im using STM32 firmware, and Im using PWM.When I hook a multimeter up to the vfd 10v in, the voltage physically drops near to Zero if a lot of speed adjustments are done. So I can see now what is happening but iv no idea why the voltage drops so much. It must be something to do with how remora outputs the signal ?
- Spyderbreath
12 May 2025 21:05 #328309
by Spyderbreath
OK, at this point I think I need to rip out this junk, out of production, no clear manual VFD and buy a new unit that has a video on how to set it up. At least that will eliminate one variable as I have no way of knowing if it was ever set up correctly and that subject is way off topic for this forum.
So if I can get a VFD that I can program and setup correctly, you all think what I have for a configuration will work then?
- Murphy
12 May 2025 21:18 - 12 May 2025 21:23 #328311
by Murphy
I wouldn't give up on the VFD yet, if it requires 0-10v it should work. I think you can test it externally with a potentiometer. Post your .hal file. You can hook a multimeter between com and AI1 of the controller . If that's still 0v there is more than likely something wrong with the code.
Look at remora.sp.0 in halshow and see what it's doing when you adjust speed
Last edit: 12 May 2025 21:23 by Murphy.
- Murphy
12 May 2025 21:21 - 12 May 2025 21:41 #328313
by Murphy
Thanks Cakeslob, I forgot your using the stm32 :/ the code in the hal file is the same for 0-10v and PWM ? Just the gain determines the difference?
In my VFD there is an option for 0-10v, 0-5v and external digital signal. Is it 0-5v or digital signal for PWM ?
@scotta , any ideas why it's doing this?
Last edit: 12 May 2025 21:41 by Murphy.
- Spyderbreath
12 May 2025 21:27 #328314
by Spyderbreath
For now I'll address the next question I have. My machine was built with all 6 proximity sensors wired in series inside the machine with only 1 wire for signal. Homing works but any attempt to add the limit switch part in results in a failure to home after the first axis, saying that a limit switch was tripped. Reading through the forum, I saw a few mentions that it should be possible, but there were no actual examples of how it is done. The best I found was one with all 3 homes on one pin and all 3 limits on another. For now it is moving OK, (I figured out how scale works) and got it set right. Tell it to move 10mm and it moves 10mm. so I can fall back on the soft limits... Better than nothing.
Time to create page: 0.240 seconds
