Remora - NVEM / EC300 / EC500
- Thayloreing
- Thank you received: 3
18 May 2025 21:11 #328716
by Thayloreing
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Scotta, do you happen to know what the error I'm having means? It seems like it's not communicating with the cloud in any way.
- JPeters
18 May 2025 22:06 #328717
by JPeters
Replied by JPeters on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello scotta,
thank you for your quick reply. Yes, that is exactly what I thought myself.
The EC500 is powered by an external power supply. From the 6 pin header, GND, SCK and SDO have been connected to one of the probes.
I don´t have any kind of schematic on hands for the EC500. So I am not shure, why the header pin is labeled SDO. I would expect SDIO for a sufficient SWD connector. Is your header labeled with a SDO too?
My EC500 is labeled with IMXR_EC500 2023-05-18
Up to now, there has not been a single successful flash. From within MCUExpresso, I am at least able to build your application.
If this is not going to be successful: do you think, your actual project with W5500 and raspberry pi pico is as powerful as the 1052 solution and could be a viable alternative?
Thank you very much. I will try to give more details tomorrow.
Cheers Julius
Cheers Julius
- DarkPhoinix
- Thank you received: 6
19 May 2025 11:17 #328735
by DarkPhoinix
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
is there a way to download previously uploaded nvem-rt1052.txt from NVEM?
- scotta
- Thank you received: 480
19 May 2025 20:30 #328754
by scotta
Remora supports quite a number of 3D printer boards. The EC300/500 being 24V IO is more suited when using industrial hardware.
I'll need to check the labelling on my boards. With MCUExpressoIDE does it report an error when trying to connect. It may give some clues.Hello scotta,
Cheers Julius
- scotta
19 May 2025 20:33 #328755
by scotta
Unfortunately, no. It's a one way process.
The following user(s) said Thank You: DarkPhoinix
- DarkPhoinix
19 May 2025 20:37 #328756
by DarkPhoinix
Isn't there a way to calculate SCALE in a precise way? Unfortunately the seller of my steppers and Drivers doesn't give me datasheets and it's really difficult to set them up properly, except trying random values. I also tried with math but nothing I couldn't get low error values Scale=scale_set*Dist_measured/Dist_Insert
I wanted to give it a high pulse/rev value to have a higher resolution, but I couldn't get precision in long movements. I put your values and after a slight change of scale everything went well!
Warning: Spoiler!At the risk of the blind leading the blind, to me that is not quite the right question. That chart is for your micro-stepping. Like the 800 is 4 microsteps, if you're using a 1.8 deg. stepper. I have always looked at it this way - What are you doing with the motor? If your opening a door or driving a ram, picking 800 would be fine, but using that on a belt or lead screw may very well end up leaving artifacts in the work due to the rougher movement between points. The downside is the more micro-steps you have the more torque you lose. 3200 (16 micro-steps) seams to be a reasonable middle ground that most use as standard. The controller will put out as many steps as directed by LinuxCNC to make a revolution, just a matter of how fast it can do it.
Whatever you chose, that gets figured out when you tell LinuxCNC in your .ini file how many pulses it takes to move one unit. That is set with the SCALE on each axis. Like for me, I have 16 micro-steps (3200) and a 5mm pitch screw, which works out to SCALE = 640 or -640 depending which way you need the motor to move.
- DarkPhoinix
19 May 2025 20:49 #328758
by DarkPhoinix
Thank you for doing this amazing job and allowing me to use linuxcnc with my low budget hardware!
Thanks a lot, I'll do some bck just to be safe.
Warning: Spoiler!DarkPhoinix post=328735 userid=35952 is there a way to download previously uploaded nvem-rt1052.txt from NVEM? Unfortunately, no. It's a one way process.
- scotta
19 May 2025 20:51 #328759
by scotta
I'd always recommend calculating the joint SCALE based on the hardware. ie steps per revolution of the stepper motor and then the leadscrew pitch etc. If the actual movement achieved is not correct I'd be suspicious of lost steps, especially if micro stepping.
- DarkPhoinix
20 May 2025 16:15 - 20 May 2025 16:28 #328817
by DarkPhoinix
the seller does not give me any documentation. The only things I have are:
Driver
Stepper: Step angle1.8∘±5%
in the TXT file i have set:
Frame:
SFU2005 and SFU1605 ball screws Repetitive positioning accuracy: 0.05mm
Driver
Pulse/rev SW5 SW6 SW7 SW8
Default on on on on
800 off on on on
1600 on off on on
3200 off off on on
6400 on on off on
12800 off on off on
25600 on off off on
51200 off off off on
1000 on on on off
2000 off on on off
4000 on off on off
5000 off off on off
8000 on on off off
10000 off on off off
20000 on off off off
40000 off off off off
"Thread": "DMA",
"Type": "DMAstepgen",
"Comment": "Y - Joint 1 step generator",
"Joint Number": 1,
"Step Pin": "P1_24",
"Direction Pin": "P1_31",
"Step Length": 7,
"Step Space": 2
Frame:
Last edit: 20 May 2025 16:28 by DarkPhoinix.
- Murphy
- Thank you received: 5
20 May 2025 19:18 - 20 May 2025 19:19 #328827
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
@ Thayloreing Looks like you have no Comms with the board. Which could be why you can't upload the config to the board. Look back in the posts there is steps there to change the IP address for the board to 10.10.10.10.
@scotta, have you tested the v5 boards with CSS ?. I'm having issues only in CSS mode. Signal keeps dropping when there is speed changes during CSS. Voltage newly drops to zero, once speed changes stop it goes to the required speed. I'm thinking it could be the 0-10v chips on the EC500's.
Last edit: 20 May 2025 19:19 by Murphy.
Time to create page: 0.276 seconds
