- Hardware & Machines
- Computers and Hardware
- Bigtreetech new allwinner based CNC board? posable cross use
- Micromachining
13 Sep 2022 15:45 #251816
by Micromachining
Bigtreetech new allwinner based CNC board? posable cross use was created by Micromachining
Bigtreetech has released the CB1 which is a Allwinner-based pin for pin replacement for the pi CM4 they also have PI4 adapter boards and more importantly CNC boards designed to plug pi4 or the CB1 directly. I wonder if any of the allwinner work would cross over or remora.
biqu.equipment/collections/control-board...ts/pi4b-adapter-v1-0
The following user(s) said Thank You: Bari
- Micromachining
13 Sep 2022 15:49 #251817
by Micromachining
Replied by Micromachining on topic Bigtreetech new allwinner based CNC board? posable cross use
Also there are readily available and cheap
- cakeslob
- Thank you received: 280
13 Sep 2022 17:22 #251829
by cakeslob
Replied by cakeslob on topic Bigtreetech new allwinner based CNC board? posable cross use
Ive had one for a while now, but Im waiting for a better os image.
Last time I checked,
there was no support for odd screen resolutions (800x480, 1024x600, etc)
There is no DSI support, so that is very disappointing.
Dont know if there is SPI drivers for it yet, or if the linuxcnc SPI drivers (hm2/remora) will work.
Does anyone know if H616 is supported by the allwinner lcnc driver?
I dont know to much about it, and didnt know if H616 counts as H6
- Bari
- Thank you received: 234
14 Sep 2022 21:08 - 14 Sep 2022 21:11 #251934
by Bari
Replied by Bari on topic Bigtreetech new allwinner based CNC board? posable cross use
We have to make a better Linux image. Waiting for armbian or similar hell will free over first and it still will need work.
linux-sunxi.org/H616#Documentation
Wish you would have mentioned this board earlier.
Manta M4P/M8P Control Board with CB1/CM4
biqu.equipment/products/manta-m4p-m8p
CB1 Allwinner H616 Linux control board for $27 that plugs into a 4 or 8 axis STM32 Remora controller board Manta 4 ($40) or Manta 8 ($98)
Allwinner H616
STM32Gx
www.st.com/en/microcontrollers-microproc.../stm32g0-series.html
Allwinner H616
STM32Gx
Last edit: 14 Sep 2022 21:11 by Bari. Reason: better links
Time to create page: 0.281 seconds
