Using google drive on linuxcnc machine
3 years 10 months ago #259327 by transistorman
Hi All,
In the past I've used Dropbox to transfer files to my linuxcnc machine running 2.8.4 Debian 10, but they have since dropped support. I did a quick writeup on installing google drive and thought you all may be interested:
transistor-man.com/linuxcnc-google-drive.html
The setup is a SCARA used for acrylic painting. Surprisingly the latency testerizer does not indicate any significant difference before / after installation.
-Dane
3 years 9 months ago #260924 by tommylight
I use FileZilla to move files over local netwok, it is free, and should also be available for windows.
3 years 9 months ago #260993 by rodw
Simple way to use drive is just use your Google account in Chrome or Firefox browser.
I use many PC's during a working day so its pointless syncing drive to a HDD anywhere.
The best way to work with files on your network is to use Samba. Give users access to their home folder and you have full access to all your linuxcnc files. Then map a network drive on Windows to the nc_files folder.
Its a bit tricky to get Win 10 to talk to Samba. There is a poliy setting that needs changing. But don't ask me what the policy is!
  • camaliyab
  • New Member
  • New Member
3 years 1 week ago - 3 years 1 week ago #283625 by camaliyab
Replied by camaliyab on topic Using google drive on linuxcnc machine
I use to mount google drive on mac Commander One
Edited by moderator to remove the suspicious link.
Last edit: 3 years 1 week ago by tommylight. Reason: remove the suspicious link
3 years 1 week ago #283639 by tommylight
@camaliyab
If you post again that type of links, you will be banned.
3 years 1 week ago #283653 by Cant do this anymore bye all
I'm a dedicated Linux user so I find mounting folders via sftp via the file manager easy. Or via "sneaker net".
Time to create page: 0.208 seconds
