isolcpus=1,2,3 does not isolate on Raspberry Pi 4Bx4Gb 5.15.65-rt49/2.9 32bit
3 years 7 months ago #266105 by elovalvo
I was tinkering trying to reduce latency on a pi3b  and found what looks like a similar issue with isolcpus
  • Raspberry  pi 3b
  • I'm running Linux raspberry pi  5.15.84-v8+ #1613  SMP PREEMPT  aarch64 GNU-Linux
  • compiled Run in place  as I couldn't get debuild to complete
  • echo -n ' isolcpus=1,2,3 idle=poll processor.max_cstate=1' | sudo tee -a /boot/cmdline.txt
  • checked all ok
  • from terminal cat /boot/cmdline.txt      isolcpus=1,2,3 idle=poll processor.max_cstate=1
  • from terminal launched latency-histogram
    • from terminal it says Note:  using POSIX non-realtime
    • in histogram is says 4 cores no_isolcpus
      Regards
      Nick
What is the contents of the /boot/config.txt file?
The OS "Linux raspberry pi  5.15.84-v8+ #1613  SMP PREEMPT  aarch64 GNU-Linux" is not realtime
3 years 7 months ago - 3 years 7 months ago #266107 by nickom44
Hi elovalvo,
Here's the contents .
Regards
Nick
GNU nano 5.4 config.txt # uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
## Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
[pi4]
# Run as fast as firmware / board allows
arm_boost=1
[all]
Last edit: 3 years 7 months ago by nickom44. Reason: more info
3 years 7 months ago #266192 by rmu
did you run "sudo make setuid" after building linuxcnc? without setuid bit rtapi_app doesn't have permission to get realtime scheduler priority.
3 years 7 months ago #266274 by elovalvo
Hi elovalvo,
Regards
Nick
From what I see missing any line of the type
kernel=vmlinuz-XXXXX
and therefore the operating system is not realtime.
If you want an image that definitely works on Raspberry Pi 3 you can use the one you find here: forum.linuxcnc.org/9-installing-linuxcnc...3b-pi?start=0#260915
3 years 7 months ago - 3 years 7 months ago #266276 by rmu
you are right, the system isn't running the preempt-rt kernel.
proper uname (except for aarch64) should be Linux raspberrypi 5.15.65-rt49-v8+ #1 SMP PREEMPT_RT Tue Sep 6 18:12:35 BST 2022 aarch64 GNU/Linux
Last edit: 3 years 7 months ago by rmu.
Time to create page: 0.181 seconds
