Mesa card issues Maho MH800E Retrofit Project
31 May 2025 15:32 #329450 by Cooped-Up
Greetings everyone, I am starting a retrofit on an older maho MH800E following some of RotarySMP's documentation. I have purchased quite a few mesa cards (5i25 w/7177, 7i74, 7i73, and 7i84) I am just trying to get familiar with all of this stuff as I have never done a linuxcnc project before. I am good with wiring and I know enough about programming stuff but I am having a hard time getting the computer to talk with the 7i77. it appears to be seeing the 5i25 just not anything else. I bought the kit of both 5i25 and 7i77 so I assumed the firmware would be the right one but I have read elsewhere this may not be the case so possibly need to get some new firmware installed. I could also be doing the config wrong as I was a bit confused when it was asking about the 2x7i77 with one 7i77 that is what I picked. and before that it asked about parports I assumed it was asking if I was going to use a combination of parallel ports with the mesa cards? it could be referring to the ports on the 5i25 but again I was unfamiliar with this stuff. Any tips or suggestions would be very helpful
31 May 2025 15:56 - 31 May 2025 15:58 #329451 by PCW
You need both the correct firmware on the 5I25 (or 5I25T) and the 7I77
connected and fully powered before the 7I77 will be detected.
Suggested 5V power arrangement is:
5I25 W2 down    ( No P3 5V power)
5I25T W3 down  ( No P3 5V power)
7I77 W5 right (no cable 5V power)
5V supplied to 7I77 TB1
Note that the firmware for the 5I25T and 5I25 is different and not interchangeable.
If you ordered the 5I25/5I25T with a 7I77 from Mesa, the 5I25/5I25T would normally
have been pre-configured for use with the 7I77
In any case you can look at the pinout of the firmware with:
sudo mesaflash --device 5i25 --readhmid > pins.txt
or
sudo mesaflash --device 5i25t --readhmid > pins.txt
and post pins.txt here for confirmation
Note that the error has nothing to do with either the 5I25 or 7I77
but rather some issue with hal_input
Last edit: 31 May 2025 15:58 by PCW.
31 May 2025 15:59 #329452 by tommylight
Replied by tommylight on topic Mesa card issues Maho MH800E Retrofit Project
Connect the 7i77 the DB25 going outside the PC.
And no, those are not parallel ports so do not choose any in the wizard, although they can "play" as parallel ports at much, much higher speeds.
Use mesaflash to check the firmware in 5i25 is for 7i77
mesaflash --board 5i25 --readhmid
or similar, just shooting from memory here.
And make a new config, do not chose anything except the axis and encoders you need, save, test.
Do not choose MPG or anything, nothing, until you get things working somehow, you can edit and add or remove later at any time, you can have as much configs for it as you like, etc, so small steps.
And have a read through this for wiring and tuning, no skipping steps:
31 May 2025 17:30 #329454 by Cooped-Up
Replied by Cooped-Up on topic Mesa card issues Maho MH800E Retrofit Project
I didnt think I wanted any parports so this is not something I selected. right now I do just have the basic stuff selected nothing crazy. I entered in that sudo mesa flash line and I am not seeing anything refering to the 7i77. I do have the 5i25t kit. I am supplying power to the 7i77 via a power supply the lights are on and I had moved the jumpers on the 5i25. should I be able to ask mesaflash for info on the 7i77 because that didnt work for me.
31 May 2025 17:33 #329455 by Cooped-Up
I should also clarify that it is pulling up a lot of information on the 5i25 but I dont know if it would plainly tell me the firmware version with 7i77 in it thats all.
31 May 2025 17:59 #329457 by PCW
You need both 5V on 7I77 field power applied for the 7I77 to be full operational
and posting pins.txt here will help verify if you have the correct firmware installed
31 May 2025 21:00 #329470 by Cooped-Up
here is that, didnt think to look for a file, I am new to linux so the command didnt click till it wasnt doing anything lol.
31 May 2025 22:54 #329474 by PCW
Yep, that is 7I77 firmware.
02 Jun 2025 02:13 #329530 by Cooped-Up
I have spent some more time trying to troubleshoot why I cant launch the software, I cant seem to figure out where I am going wrong, I have it real barebones. I am sure I am configuring something wrong I just cant get past the error message when I click the launch icon. it tells me to look at the inputs config or whatever but I am not even sure what that is. I think I am supposed to enter a serial port number somewhere for setting the mode that the 7i77 is in but I cant find that in the hal or ini file...
02 Jun 2025 02:41 #329531 by PCW
Can you post the terminal log?
( start Linuxcnc from the terminal and copy-paste the messages printed )
The previous error indicated an issue with a (probably USB) input device like a MPG
I would create  a configuration without the added input device to get past this error
for now
