latency (netowork?) 7010 with 7i96s+7i84u
22 Nov 2025 15:58 #338999 by mooser
I'm setting up a new system and I'm sometimes getting a unexpected realtime delay on task 0 with period 1000000 error (mostly on startup) and there was a few error finishing read ones as well. After much reading and tinkering I've got it to this point and I'm not sure if it's OK or not.
7010, all the extra anything in the bios has been turned off, only using the 1 core
built in intel network controller, onboard graphics
Ping 192.168.1.121 was up around 350ms, made the changes to the networks file and it is about 150ms now, mainly sits just under 100ms so I think the network to card connection is ok.
Histogram looks pretty "fat" though ???
Also had a tri-peak at one point... might have been a glitch though
Is it safe to just bump the period up some or is there something I can actually do to make this better
M
  • Moderator
  • Moderator
22 Nov 2025 17:24 #339003 by tommylight
Replied by tommylight on topic latency (netowork?) 7010 with 7i96s+7i84u
Try this:
latency-histogram --nobase --sbinsize 1000 --show
and also paste the result of this:
sudo chrt 99 ping -i .001 -q-c 60000 192.168.1.121
22 Nov 2025 17:48 #339007 by mooser
Replied by mooser on topic latency (netowork?) 7010 with 7i96s+7i84u
I ran it a couple of times
cnc@router:~$ sudo chrt 99 ping -i .001 -q -c 60000 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
--- 192.168.1.121 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.074/0.086/0.256/0.008 ms
rtt min/avg/max/mdev = 0.074/0.086/0.377/0.008 ms
The histogram l ran on it's own and with 5 gears running
22 Nov 2025 17:52 #339009 by unknown
Replied by unknown on topic latency (netowork?) 7010 with 7i96s+7i84u
The i5 3470 is a four core chip.
Might be worth checking your BIOS to see if there is a setting that either enables or disables the 4 cores.
22 Nov 2025 17:59 - 22 Nov 2025 18:04 #339011 by mooser
Right now I've got it turned down to only a single. One of the many documents on tuning I came across seemed to want the 7010 to run with it set to single. I'll reset it to all in the bios and re-post
rtt min/avg/max/mdev = 0.065/0.102/0.281/0.018 ms
M
Last edit: 22 Nov 2025 18:04 by mooser.
22 Nov 2025 18:15 #339012 by PCW
I would use all cores but set isolcpus=3  in the kernel command line
otherwise you run all realtime and non-realtime code on the one core.
(plus reducing overall performance)
In addition, pinning the Ethernet IRQ to the last CPU (LinuxCNCs CPU)
will help with network latency.
22 Nov 2025 18:36 #339015 by mooser
altered the grub
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet isocpus=3"
GRUB_CMDLINE_LINUX=""
does that second grub_cmdline_linux="" wipe out the line before?
I read some of the doc on pinning but honestly I really got lost on how to actually get that done.
Is there a pinning for dummies file somewhere? (there was a few links to a doc by Rod but the link is dead)
Thanks again, rebooting.
BTW, what part of this am I looking to get better?
22 Nov 2025 18:50 - 22 Nov 2025 18:51 #339017 by PCW
You can try this script to pin the IRQ:
File Name: pinirq_2025-11-22.txt
File Size:1 KB
Download and set as executable with chmod +x pinirq.txt before running:
sudo ./pinirq.txt [ethernet_device_name]
Where [ethernet_device_name] is something like eno1, eth0, enp2s0 etc
You can use
ip a
To determine the realtime Ethernet device name by its IP address
Last edit: 22 Nov 2025 18:51 by PCW.
The following user(s) said Thank You: rdtsc
22 Nov 2025 19:11 #339018 by mooser
sudo ./pinirq.txt eno1
Cores: 4
Old CPU Mask: f
Set device eno1 IRQ 24 CPU mask to 8
Looks like it did something, how can I tell if it worked?
M
  • Moderator
  • Moderator
22 Nov 2025 19:44 #339019 by tommylight
Run LinuxCNC with the card on, see if it faults or drop connection, while watching youtube and doing anything to stress the PC.
No need for the machine to be actually milling.
Time to create page: 0.397 seconds
