Remora sk1.4 with ethernet?
10 months 4 weeks ago - 10 months 3 weeks ago #339615 by Punisher
I have a skr1.4 turbo board. Would like to use ethernet to connect it to a pc instead of using a Raspberry Pi. Did see the demo of it working. Searched through the threads here and couldn't find how to wire and configure it.
Last edit: 10 months 3 weeks ago by Punisher.
10 months 4 weeks ago #339622 by tommylight
10 months 3 weeks ago #339749 by Punisher
I looked through that thread before I posted. Couldn't find anything on how it was wired.
10 months 3 weeks ago #339751 by tommylight
Docs on github linked on that topic, at the very start of it
remora-docs.readthedocs.io/en/latest/har...ring-to-raspberry-pi
10 months 3 weeks ago - 10 months 3 weeks ago #339777 by Punisher
I searched through the documentation before starting this thread. That only shows how to wire it to a raspberry pi.
As I said at the beginning I do not want to use a raspberry pi. I want to use a w5500 ethernet board. Then connect with a pc. Like shown in the demo video.
10 months 3 weeks ago #339785 by tommylight
The same pins used on RPI are on the W5500, those are the SPI pins so the wiring is the same.
Just check the pin naming.
The following user(s) said Thank You: Punisher
Time to create page: 0.609 seconds
