Remora sk1.4 with ethernet?
10 months 3 weeks ago #339931 by Punisher
Thanks that clears up most of it. On the 1.4 board there's pin p1.31. What would that connect to on the w5500 board? In the video there's a power supply going to the w5500 board. Does it need 5v, 3.3v, or both? The documentation shows that it's possible to power a raspberry pi with the 1.4 board. Is it possible to do the same with the w5500 board? Looks like there's 5v there.
10 months 3 weeks ago #339952 by scotta
Replied by scotta on topic Remora sk1.4 with ethernet?
The SKR1.4 is not actively supported and the ethernet demo was an early concept testing. Please check this link for ethernet supported boards.
remora-docs.readthedocs.io/en/latest/har...hernet/ethernet.html
Cakeslob also has his F4 repo
github.com/cakeslob/Remora-STM32F4xx-W5500
10 months 3 weeks ago #339963 by Punisher
Trying to repower some machines. Want to use a control board with integrated stepper drivers, so it will fit inside the machine. That rules out using the Remora compatible ethernet boards.
There isn't a whole lot of room. Not sure yet if there is room to fit a skr and raspberry pi. Having the raspberry pi inside the machine isn't ideal. Would need a separate pc to use for remote desk toping to it.
Was planning on using an Intel NUC. That's much more powerful than a raspberry pi. Also has a proper enclosure.
Guess if I had to I could mount the raspberry pi on the back of the monitor like I was going to do with the NUC. Then run the spi wires to the machine. Going to need a bulkhead connector anyways. Wouldn't really matter if it's ethernet or a 6 pin connector.
With another machine I used a Genmitsu usb Mach 3 board. It's a compact controller like what I'm looking for. Unfortunately that has been discontinued, so I'm looking for an alternative.
The other option is to use the skr as is, or similar grbl board. The ones for routers are much smaller. Tried Universal Gcode Sender a few years ago and didn't really like it. It worked, but is very limited compared to Linuxcnc or Mach 3.
Time to create page: 0.416 seconds
