How to install simplescreenrecorder on old version of Debian?
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Dec 2025 04:16 #340576 by RotarySMP
Hi All,
My Maho 400E is still running an old version of Debian, with XFCE, that would have been the live CD back in about 2019. For my videos, I need to install simplescreenrecorder, as pointing a camera at the screen is lame.
I have tried:
sudo apt-add-repository ppa:maarten-baert/simplescreenrecorder
sudo apt update
sudo apt install simplescreenrecorder
This fails with "unable to locate simplescreenrecorder."
Please help with this. I seem to forget all linux knowledge the instant whatever I was trying to do gets done :/
Cheers,
Mark
  • Moderator
  • Moderator
27 Dec 2025 06:22 #340580 by tommylight
No idea, but you can always use OBS-Studio
sudo apt install obs-studio
  • RotarySMP
  • Platinum Member
  • Platinum Member
27 Dec 2025 06:31 #340581 by RotarySMP
I could but that is a pretty huge overhead on a old pc.
27 Dec 2025 11:09 - 27 Dec 2025 11:10 #340588 by rodw
Well you could try upgrading to Trixie which has linuxcnc 2.95 and simplescreen recorder as standards. 2.97 is included in testing so you can use APT pinning to get 2.9.7
packages.debian.org/search?keywords=simp...e=trixie§ion=all
Last edit: 27 Dec 2025 11:10 by rodw.
  • RotarySMP
  • Platinum Member
  • Platinum Member
27 Dec 2025 11:29 #340589 by RotarySMP
I am sticking with LCNC 2.7, as it will be a risk to update to 2.9, given the switch to joints, and the gearbox comp I have working.
I really just want simpescreenrecorder. I use this on both my lathes. I just have little clue of how to get the repository working.
I also tried this method, but it also failed.
27 Dec 2025 13:52 #340596 by Surmetall
maybe a silly idea. but you could install Teamviewer and record the screen on your Cutter-PC.
i use Teamviewer all the time on my machines and i cant note any lag.
Greetings
Tom
27 Dec 2025 15:48 #340601 by rodw
A bit left field but if this is for your YouTube channel, I use a video switcher and send the Linuxcnc monitor to one input on the switcher ( I had to buy a VGA to HDMI adapter for one machine). The video and audio (from a seperate microphone) gets recorded to SD card on the switcher and I can do picture in picture etc when recording.
I use a MovMagic switcher but a similar one is a Black magic ATEM mni
  • RotarySMP
  • Platinum Member
  • Platinum Member
27 Dec 2025 16:06 #340602 by RotarySMP
Thanks Rod, I have an Atem mini Pro Iso, which I use for my live streams, but having it set up for a simple task like screen recording is overkill. For the times I need the screen recorded on the Schaublin I
just use simplescreenrecorder and drop the files onto a thumb drive.
Why it is so hard to install a simple program on Linux, which I have installed easily on two other flavours of linux.?
  • Moderator
  • Moderator
27 Dec 2025 16:24 #340604 by tommylight
Choose a mirror near you, download, double click.
packages.debian.org/sid/amd64/simplescreenrecorder/download
If it complains:
sudo apt install gdebi
P.S.
did you do a
sudo apt update
before trying to install? Sorry for asking, but way to often this gets left out.
27 Dec 2025 17:03 #340605 by unknown
What exact version of Debian are you using ?
When you do an apt update it will list the repos and the version, wheezy or bullseye or whatever.
If it's bullseye or up it's available in the repos, if not you may have to install from source, which brings along a whole manner of other issues. And to make whatters worse there does appear to be some issues with wheezy.
From my understanding Sid is the "unstable"branch, so I doubt that anything from Sid would help.
Time to create page: 0.270 seconds
