LinuxCNC-PC - Remora - OrangePi3 LTS - BTT SKR V1.4 Turbo
27 Jul 2026 12:53 #348097 by ukhellfire
Ive started a new project.
I want to control a mini 3 axis cnc ive built, with LinuxCNC. The problem I hit, i have a BTT SKR v1.4 Turbo board, a PC and an OrangePi3 LTS SBC board.
The Plan:
Install LinuxCNC Debian on the PC. Install and configure Remora on the PC. Connect to the OrangePi3 LTS through ethernet connection. This in turn, will be connected to the BTT SKR v1.4 Turbo board via SPI. The SKR board has the latest LPC1769 supported Remora firmware installed on it.
Follow this repo for my progress. Feel free to collaborate!
github.com/afaulkner420/LinuxCNC-Remora
27 Jul 2026 16:35 #348101 by tuxcnc
Nonsense.
This will be not cheaper and not better than chinese 7i92 + cncshield (~60 US dollars on Aliexpress).
I have small table milling machine controlled by ESP32 + W5500 + cncshield (hal2udp project) - it is cheapest solution and work well.
27 Jul 2026 16:39 #348102 by ukhellfire
Actually this is cheaper. I already have it running on GRBLHal, and I fancied a challenge.
I have all the hardware, so buying supported/prebuilt hardware, is more expensive…
Plus, this could open up a lot of extra windows and doors!
27 Jul 2026 16:39 - 27 Jul 2026 16:43 #348103 by NWE
Am I understanding correctly, the Pi in this project exists purely for bridging ethernet udp <-> spi?
I am always interested in new ideas. Sometimes new ideas hatch breakthroughs.
Last edit: 27 Jul 2026 16:43 by NWE. Reason: typo
27 Jul 2026 17:13 #348104 by ukhellfire
Yes I believe you are.
PC → Ethernet → Orange Pi → SPI → SKR
Again, read. Through my repo. It explains everything! In depth!
27 Jul 2026 17:23 #348105 by tuxcnc
You're wrong.
You will waste a lot of time (that's also money) and you will reach a wall that you can neither get around nor jump over.
Short time ago I have removed four Remora EC500 from working machines, because this project has no future.
I spent many hours with this hardware and not solving some troubles (stupid 3,3V differential outputs not fitting motor drivers and not working spindle encoder).
I bought four Chinese 7i92, because it was cheaper and better, and now I have many time for other projects...
27 Jul 2026 17:40 #348106 by ukhellfire
Well I’m always up for a challenge!
I reckon I can get this running as reliable as ever.
This was the best solution I could think of, as usb isn’t an option. Then realised, this has the potential of actually being quicker and more reliable than usb.
The following user(s) said Thank You: NWE
  • Moderator
  • Moderator
27 Jul 2026 19:44 #348111 by tommylight
Go for it!
Despite Tuxcnc being right about the time and effort, humanity would not reach very far if it did not try stuff that may or may not be "standard".
27 Jul 2026 20:05 #348114 by 3404gerber
I wouldn't do this, but I'll follow the topic as I'm sure I'll also learn something. Personally, I would have tried to run LinuxCNC directly on the OrangePi3. Or added a W5500 to the SKR.
A couple of months ago, I did some tests with Remora and a RP2040; I watched Rod's video on Youtube to achieve real time performance on the ethernet connection between a Pi400 and the Pico. My guess is that you'll have to compile a real time kernel for the Armbian OS too (did it last year for a Radxa Zero 3E, worked more or less).
27 Jul 2026 22:48 #348115 by ukhellfire
Yes running Linuxcnc on the OrangePi would be easier. And the board would probably run it extremely well. But again, that’s normal.
if I’d opted for the w5500 on the SKR, I’d have to have ported the code over from the stm32/rp2040 side of things. Not hard, but not as challenging as this.
So I opted for this. Means I still have the main pc doing all the hard legwork, and the OrangePi just bridging the traffic over to the SKR. Which I think long term, is the best option, performance wise. This was the SBC isn’t doing a lot of work at all.
the last time I did anything challenging, was when I originally bought up Armbian for the OrangePi 3 LTS. This was nearly 5 years ago, and it’s the same board I’m using today! Never found a use for it! I had it running klipper and a 3d printer for a while
Time to create page: 0.178 seconds
