Need to turn 90 degs.
14 years 9 months ago #16959 by BigJohnT
Replied by BigJohnT on topic Re:Need to turn 90 degs.
Unfortunately the docs are correct but confusing to read... the correction is on the list, thanks for finding the confusion. And my mistake in linking 2.5 docs which support P0 for the current coordinate system. I guess I'm excited about 2.5 fixing to hit the streets and tend to wander over to those docs...
2.4.x docs are here:
linuxcnc.org/docview/html/gcode_main.htm...:G10:-Set-Coordinate
14 years 9 months ago #16961 by cwebs
Replied by cwebs on topic Re:Need to turn 90 degs.
Ok. I tried P1 and got no error using Mach3 Sim. But The work peice was not turned 90 degz. I will try in in LinuxCNC tonight. THanks John.
I knew you made that boo boo but was saving your feelings. Carl
14 years 9 months ago #16962 by BigJohnT
Well the mack sim will be different for sure...
14 years 9 months ago #16963 by andypugh
Replied by andypugh on topic Re:Need to turn 90 degs.
You might not see it. I only saw it in the EMC2 sim because the right-arrow started moving the Y axis on-screen
I should have remembered to try 45 degrees, then all arrow keys ought to move both axes…
14 years 9 months ago #16964 by cwebs
THe P1 did the trick. It doesn't work in Mach3 Sim but you were right Andy it does work just fine in LinuxCNC. You see John, I knew if you read the man you would be able to do it! Thanks guys, Carl
14 years 9 months ago #16966 by BigJohnT
Well the statement about jogging is correct in the 2.5 docs :)
linuxcnc.org/docview/2.5/html/gcode/gcod...em_a_id_sec_g10_l2_a
Time to create page: 0.372 seconds
