Error when using circular interpolation on lathe
14 years 8 months ago #17406 by BigJohnT
When I get stuck hand coding an arc I draw it in cad and find the start, end and offset points then it usually works.
For any plastics you want as big as possible chip to pull the heat out of the material, of course that depends on your cutter size and material size. Also use a dead sharp insert like the razor sharp ones for cutting aluminum.
Time to create page: 0.215 seconds
