Gcode error
14 years 6 months ago - 14 years 6 months ago #18982 by rene
Gcode error was created by rene
Hello,
I build this machine:
I want that every Operator our company can use this machine so i made a gladevcp userinterface,
The glade panel is standalone and loads after the axis program.
All hal boxes in this panel are connectet with analog ports.
The gcode programm read these analog ports
The problem is when axis starts the analog ports are zero and axis shows an error message.
how can stop axis from sending this gcode error messages.
In the attach is this gcode programm. Error is in Line 115
Sorry for my bad english.
File Name: gcodeprogramm.ngc
File Size:4.28 KB
image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/Bildschirmfoto-1e1d951335464fa9d868fb8cabf946dd.png
Last edit: 14 years 6 months ago by rene.
14 years 6 months ago - 14 years 6 months ago #18983 by BigJohnT
Replied by BigJohnT on topic Re:Gcode error
You will have to somehow not have a negative feed value to prevent the error. Perhaps use an absolute number that can not be negative.
Very nice video and a neat machine... you do have a lot of error messages on your screen to work out.
Last edit: 14 years 6 months ago by BigJohnT.
14 years 6 months ago #18984 by Rick G
Replied by Rick G on topic Re:Gcode error
Did not have time to follow the logic but perhaps if after...
#<rueckfahrspeed> = [#<temp1> - #<pos1>] / [#<schneidzeit> + #<haltezeit> * 60]
You added logic that...
If <rueckfahrspeed> is less than or equal to 0
#<rueckfahrspeed> equals 10 or some number that will not cause a problem
Then continue, again I have not followed your logic but earlier in your program you have...
#<rueckfahrspeed> = 10
Rick G
14 years 6 months ago #18985 by BigJohnT
Good idea Rick, I just tested in the Axis Sim and F0 is an acceptable G code so if less than 0 set to 0 should solve the problem.
14 years 6 months ago #18988 by rene
Replied by rene on topic Re:Gcode error
Thank you BigT for the compliment.
I have found the problem. :)
At the start of axis the parameter #<laenge> = 0
with this parameter i calculate #<rueckfahrspeed>
#<temp1> = [#<laenge> + 20]
#<leerlaufzahl> = 0
o102 while [#<temp1> GT #<maxlaenge>]
#<temp1> = [#<temp1> - #<maxlaenge>]
#<leerlaufzahl> = [#<leerlaufzahl> + 1]
o102 endwhile
so get a negativ number
If fix this with
O112 if [#<laenge> EQ 0]
#<laenge> = 1000
O112 endif
modified Gcode in the attachments
now i get no error massage but when i now start axis the interpreter hang up.
File Name: gcodeprogr...6249.ngc
File Size:4.29 KB
14 years 6 months ago - 14 years 6 months ago #18989 by rene
After exiting Axis this error is shown.
File Name: error-0e63...55a6.txt
File Size:3.61 KB
Time to create page: 0.463 seconds
