add a temporary offset
14 years 4 months ago #21120 by steeley
I need to shift my z axis up by 7mm half way through a gcode file.
Can't find the particular gcode to do this despite hours of searching.
I tried g54 but it didn't seem to do anything.
TIA
14 years 4 months ago #21123 by BigJohnT
Replied by BigJohnT on topic Re:add a temporary offset
G54 is to select a coordinate system not change an offset. Having said that you could touch off your Z in G55 at the different position and switch to G55 until you wish to switch back.
14 years 4 months ago #21126 by andypugh
Replied by andypugh on topic Re:add a temporary offset
G92?
14 years 4 months ago #21141 by steeley
Replied by steeley on topic Re:add a temporary offset
Thanks for the pointer folks-Looks like I've got a solution.
Time to create page: 0.105 seconds
