Writing gcode on windows
23 Jun 2012 13:56 #21223 by lukepighetti
Writing gcode on windows was created by lukepighetti
So I use my macbook with windows installed for all my CAD work, since I have a student version of Solidworks.
I'd like to also write my gcode on windows. The LinuxCNC machine is in the basement and it has a horrible keyboard.
I have not been able to find a single decent gcode editor on windows. You'd think there would be at least one that was decent, and there might be but I haven't found it.
All I want is syntax highlighting, function chart, and code examples / explination for each line you write.
GWizard does some of this but it's quite buggy and doesn't support things like G02 helix with multiple turns as listed in emc2 documentation.
And a somewhat unrelated question, is there any way to write gcode alongside axis and have it pipe directly in (live?) to simulate? If I must I will just run a VNC server on the LinuxCNC machine and do my writing that way with final checks in person.
Thanks,
Luke
23 Jun 2012 14:25 - 23 Jun 2012 14:29 #21224 by ArcEye
Replied by ArcEye on topic Re:Writing gcode on windows
Hi
That might be a lot to expect from any editor
gedit has a windows port
projects.gnome.org/gedit/ and see link on RHS of page
The main thing to be wary of is that you don't want windows CR/LF pairs and other formatting characters in your code.
See if it has a Unix mode.
I just have a browser open with whatever info I need, if I need to refer to something whilst coding.
axis-remote on the same machine or emcrsh (linuxcncrsh) remotely
But if you use VNC you can just remotely write and run the code on the linux machine in the first place.
That seems to be what quite a few people do
Last edit: 23 Jun 2012 14:29 by ArcEye.
23 Jun 2012 14:45 #21225 by BigJohnT
Replied by BigJohnT on topic Re:Writing gcode on windows
taiden wrote:
All I want is syntax highlighting, function chart, and code examples / explanation for each line you write.
That's quite a huge thing to ask an editor to do past syntax highlighting... I use notepad++ on my windows machine. The syntax highlighting is severely broken in gedit IMHO.
24 Jun 2012 04:57 #21244 by bjames28
Replied by bjames28 on topic Re:Writing gcode on windows
Nick on cnc-club.ru provided his version of G code highlighting for Gedit. It works very well for me.
Gedit exists for windows too . I never tried, but should work, together with syntax highlighting.
And CR/LF problem solved automatically, because Gedit can save text in Win and Unix style format.
James
27 Jun 2012 14:20 #21384 by lukepighetti
Replied by lukepighetti on topic Re:Writing gcode on windows
I decided to go the VNC route. After a few tried with vino (not working at all), tightvncserver (only loading twm), vnc4viewer (not loading anything) and now some strange thing I am not familiar with at all? I can't find the link to the install instructions but it now works completely headless, seems to be fast enough, but won't allow any opengl programs to run.
What VNC server are you guys using?
27 Jun 2012 16:08 #21394 by andypugh
Replied by andypugh on topic Re:Writing gcode on windows
The one built-in to MacOSX (CMD-K to bring up the "connect to server" dialog, and then vnc://andypugh@lathe)
Alternatively, you can try using ssh -X (or ssh -Y) and then the local X-server handles the GUI. I do this rather often.
ssh -X andypugh@mill
linuxcnc
brings up an Axis Gui window on my iMac.
27 Jun 2012 18:57 #21401 by lukepighetti
Sounds like a great alternative. I actually use a macbook so doing it on OSX is no problem.
What server side software are you using to serve the VNC connection?
27 Jun 2012 19:01 #21402 by andypugh
Again, it's built-in.
System->Preferences->Remote Desktop.
You need to set a password or OSX won't connect.
27 Jun 2012 19:03 #21403 by lukepighetti
I'm confused. Your CNC computer needs to serve the VNC connection, not your client mac.
Unless you're mac is listening for a host and you are connecting from your CNC computer?
27 Jun 2012 19:13 #21404 by andypugh
Yes, and those were instructions for the Ubuntu end.
But (for some reason) you appear to need to set the Ubuntu end to demand a password at the OSX end, or the OSX end won't connect.
But it is built-in at both ends. (And in Lion, you actually get a remote-desktop connect button when the remote machine is available too, presumably due to Bonjour)
Time to create page: 0.124 seconds
