G Code Generation
14 years 3 weeks ago #25088 by diegoroman17
Replied by diegoroman17 on topic Re:G Code Generation
I need understand more about how LinuxCNC work in trajectory planner and lookahead. Exist any document about this?Or how can I learn about this themes?
14 years 3 weeks ago #25100 by BigJohnT
Replied by BigJohnT on topic Re:G Code Generation
From the user side there is this chapter
linuxcnc.org/docs/html/common/User_Concepts.html
From a programmer side you would have to examine the code.
14 years 3 weeks ago #25122 by diegoroman17
I have readed linuxcnc.org/docs/html/common/User_Concepts.html. In critical distance say that A is 1/2 of Max aceleration but in the examples use the complete aceleration.
14 years 3 weeks ago #25125 by BigJohnT
I'm not sure if your asking a question or not? If you are can you describe it a bit differently?
14 years 3 weeks ago #25126 by diegoroman17
Ok.
There is a possibility of bug in the examples of Section 1.4. The theory says that A is half of the maximum acceleration but the examples used without dividing the maximum acceleration for two
14 years 3 weeks ago #25131 by BigJohnT
To keep up the feed rate, the move must be longer than the distance it takes to accelerate from 0 to the desired feed rate and then stop again. Using A as 1/2 the ini file MAX_ACCELERATION and F as the feed rate in units per second, the acceleration time is ta = F/A and the acceleration distance is da = F*ta/2. The deceleration time and distance are the same, making the critical distance d = da + dd = 2 * da = F2/A.
For example, for a feed rate of 1 inch per second and an acceleration of 10 inches/sec2, the critical distance is 12/10 = 1/10 = 0.1 inches.
For a feed rate of 0.5 inch per second, the critical distance is 52/100 = 25/10 = 0.025 inches.
So your saying the two examples from the manual I quoted above are wrong? What should the correct example be?
Time to create page: 0.265 seconds
