can't run dxf2gcode
13 Nov 2012 21:07 #26542 by paulstenlund
can't run dxf2gcode was created by paulstenlund
When I double click dxf2gcode_b02.py and choose run I get nothing, no error just nothing. what could be wrong??
13 Nov 2012 21:24 #26543 by BigJohnT
Replied by BigJohnT on topic can't run dxf2gcode
Run it from a terminal to see the error.
Hint prefix the file name with ./
13 Nov 2012 21:49 #26548 by paulstenlund
Replied by paulstenlund on topic can't run dxf2gcode
thanks Big John. its got to be in the wrong place I get file not found from terminal (or one of its dependants is not in the right place)
where should it live
13 Nov 2012 23:58 #26557 by BigJohnT
When you open up a terminal you are in the "home" directory. If you put the file somewhere else then you will have to change to that directory or provide the full path to file from home. So if you placed the file in the linuxcnc directory you change directory with the "cd" command.
cd linuxcnc
linuxcnc.org/docs/html/common/Linux_FAQ...._terminal_commands_a
14 Nov 2012 03:04 #26562 by paulstenlund
ok i downloaded again and extracted to "Home" apparently that is a a folder that can't be got to with the cd command. "cd \home" then enter command "dir" and all I see is "pauls".
I've downloaded again and am waiting to extract the files ... where the heck should I put them ... can't extract to "home", don't have the right permissions
Thanks for your help
14 Nov 2012 03:11 #26563 by andypugh
Replied by andypugh on topic can't run dxf2gcode
It might be your own "Home Folder" directory (which is /home/pauls/ in the filing system)
You get there most easily with cd ~/
14 Nov 2012 03:13 #26564 by BigJohnT
"dir" is a dos command in linux you use "ls"... if you type "pwd" after opening up a terminal you will see the results from "print working directory" command it will be something like "/home/paul" if you download to paul then you can just open a terminal and type in ./dxf2gcode_b02.py and it will attempt to run. BTW, where did you get the file?
14 Nov 2012 04:07 #26565 by paulstenlund
YES I've found it thank you, thank you. Now I enter /dxf2gcode_b02.py or dxf2gcode_b02 and I get "no such file or directory" or "command not found". dir shows it there
14 Nov 2012 04:19 #26566 by paulstenlund
pwd shows home/pauls, ls shows that it is in the directory neither /dxf2gcode_b02.py or dxf2gcode_02.py will work. Don't remember where I got it where do you suggest and where should I extract it to
thanks for the help
14 Nov 2012 04:35 #26567 by paulstenlund
ok tried it again with ./dxf2gcode_b02 and got "bash: ./dxf2gcode_b02.py: python^m: bad interpreter: no such file or directory"
another download? can you suggest a source?
thanks
Time to create page: 0.219 seconds
