can't run dxf2gcode
- paulstenlund
- Topic Author
13 years 11 months ago #26542
by paulstenlund
can't run dxf2gcode was created by paulstenlund
When I double click dxf2gcode_b02.py and choose run I get nothing, no error just nothing. what could be wrong??
13 years 11 months ago #26543
by BigJohnT
Replied by BigJohnT on topic can't run dxf2gcode
Run it from a terminal to see the error.
Hint prefix the file name with ./
- paulstenlund
- Topic Author
13 years 11 months ago #26548
by paulstenlund
Replied by paulstenlund on topic can't run dxf2gcode
thanks Big John. its got to be in the wrong place I get file not found from terminal (or one of its dependants is not in the right place)
where should it live
13 years 11 months ago #26557
by BigJohnT
When you open up a terminal you are in the "home" directory. If you put the file somewhere else then you will have to change to that directory or provide the full path to file from home. So if you placed the file in the linuxcnc directory you change directory with the "cd" command.
cd linuxcnc
linuxcnc.org/docs/html/common/Linux_FAQ...._terminal_commands_a
cd linuxcnc
- paulstenlund
- Topic Author
13 years 11 months ago #26562
by paulstenlund
ok i downloaded again and extracted to "Home" apparently that is a a folder that can't be got to with the cd command. "cd \home" then enter command "dir" and all I see is "pauls".
I've downloaded again and am waiting to extract the files ... where the heck should I put them ... can't extract to "home", don't have the right permissions
Thanks for your help
13 years 11 months ago #26563
It might be your own "Home Folder" directory (which is /home/pauls/ in the filing system)
You get there most easily with cd ~/
Replied by andypugh on topic can't run dxf2gcode
paulstenlund wrote: ok i downloaded again and extracted to "Home" apparently that is a a folder that can't be got to with the cd command.
Time to create page: 0.252 seconds
