- Thank you received: 240
You can work around it 2 ways....an occasional re-home would prevent positioning errors from accumulating.
ArcEye wrote:
Obviously it is preferable to sort out why you lose steps, cuts too deep and stalling, velocity to fast or whatever.
Purely as an intellectual excercise, as I don't think this is a good idea, but I wonder if you could use the non-home end limit switches as probe inputs and periodically run a probing routine?
It is fairly unusual to just miss a couple of steps (My lathe does it when pushing too big a drill with the toolpost). If it happens during a fast rather than very slow move then the motor stalls and there is no recovery possible.
Is it possible to achieve automatic homing when machine is powered on?
