SRT wrote: We can do that but in long or large roughing cycles it is a time waster, watching air cuts drives me nuts as a business owner. There are times when the insert may need changed in the middle of a roughing cycle.
SRT wrote: Looks like we lose the constant surface speed but it reads the value of the S portion of the G96 line in the code.
EX G96 D1000 S600
Hit feedhold, spindle stop, spindle restart and cycle start spindle and program resume but at 600 RPM for the rest of the program
LAIR82 wrote: Just thinking out loud, what do think it would do if we just hit program restart/un-pause and skipped the spindle re-start?
andypugh wrote: I can try it on my machine. As that is metric this is likely to have it going from 45 m/min to 45rpm, which I am not sure the VFD can even handle...
andypugh wrote: An alternative, if you are in feed-per-rev mode is to turn the spindle override down to zero. That should stop all motion too.
Though I don't really like the idea of doing things on the machine in that situation, with it all poised to move again.
Something I have never tried is turning the chuck backwards in that scenario. I wonder if the tool backs-off? I suspect not.
