G code files - from milling to laser cutting.
- grey1beard
20 Sep 2013 04:45 - 20 Sep 2013 04:48 #39041
by grey1beard
G code files - from milling to laser cutting. was created by grey1beard
I'm used to writing out G code for my 3 axis m/c working directly from paper sketches plus school level trigonometry for 2.5D patterns.
I'm now planning to get my ideas cut out by laser, and the owner can use .dxf, or .dwg.
He's running Alphacam, and mentions using .las files, but I can't find any likely info on that extension.
While I'm a competent user of of coreldraw on a windows m/c, it's going to be pretty tedious having to start from scratch in a none too brilliant installation of corel under wine, then going from .cdw(?) to .dxf, then emailing the result.
Is there a method of converting .ngc to dxf that might work in Ubuntu ?
I've seen fairly negative comments about gcode2dxf software, but that might have been improved by now.
Last edit: 20 Sep 2013 04:48 by grey1beard. Reason: extra info
- jaredts
21 Sep 2013 03:23 #39067
by jaredts
Replied by jaredts on topic G code files - from milling to laser cutting.
A simple cad program is the normal way to do this kind of work. Are you wanting to retain your current workflow of working from paper, or is there some other reason you don't want to use a cad program?
- BigJohnT
- Thank you received: 994
21 Sep 2013 19:47 #39073
by BigJohnT
Replied by BigJohnT on topic G code files - from milling to laser cutting.
You can draw the dxf files in Qcad on your Linux machine from your sketches.
JT
JT
- emcPT
- Thank you received: 95
21 Sep 2013 21:05 #39075
by emcPT
Replied by emcPT on topic G code files - from milling to laser cutting.
I use QCad for a long time. It is well worth the money.
I even made a software that reads the QCad files (arcs, lines and circles) and outputs the desired structured GCode, mainly to my plasma cutter.
- BigJohnT
22 Sep 2013 03:19 #39089
by BigJohnT
What did you write your software in?
BTW, Qcad is free...
JT
JT
- emcPT
22 Sep 2013 04:07 #39094
by emcPT
The professional version is not free. I use the professional version mostly to also support the development. I make money with it, so it is fair to pay back to those that develop the software. I tested the software for maybe 1 year, then as it suited my needs I decided to bought it.
I do not quite understand your question: what did you write your software in
- BigJohnT
22 Sep 2013 19:02 #39106
by BigJohnT
The software to output G code from dxf.
JT
JT
- emcPT
23 Sep 2013 01:06 #39110
by emcPT
I made in c# for windows platform. I needed a fast way to generate the code as I wanted, so I tested a few available programs that at the end I always needed to "clean" the output file. As I often program a bit, I made it to suit my objective.
- grey1beard
23 Sep 2013 04:43 #39116
by grey1beard
Replied by grey1beard on topic G code files - from milling to laser cutting.
Well thank you all for taking the time to contribute to my original posting, but somehow the actual question has disapeared into a discussion of a cad program.
I did include the specific question " Is there a method of converting .ngc to dxf that might work in Ubuntu ?"
If the answer is that there is no method of doing this, that alone would save me a lot of time looking, and I'll go back to using corelDraw on a windows m/c to generate my .dxf files.
- Thank you received: 1476
23 Sep 2013 11:10 #39121
Replied by Todd Zuercher on topic G code files - from milling to laser cutting.
There are free G-code to DXF conversion programs that can be downloaded. (don't know if there are any for Linux) Google is your friend.
Time to create page: 0.150 seconds
