- Thank you received: 2620
G-code to engrave numbers on cylinders
- Topic Author
I wrote this G-code to engrave angles on a lathe part. It might be handy for other things. It uses a sub for each digit, then computed-calls to call the right one.
Attachment not found
- BigJohnT
- Thank you received: 527
JT
- Topic Author
- Kirk_Wallace
- Topic Author
Kirk_Wallace wrote: If it is convenient, could you let me know if you there are any configuration or other changes I should look at?
I just tried it in the stock sim/axis-9-axis config and it was as you describe.
I changed GEOMETRY to ABCXYZYVW and then on restart the display looked as-shown in the picture above.
- Kirk_Wallace
[TRAJ]
AXES = 9
COORDINATES = A B C X Y Z U V W
HOME = 0 0 0 0 0 0 0 0 0
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.0
DEFAULT_ANGULAR_VELOCITY = 45.0
POSITION_FILE = position9.txt
MAX_LINEAR_VELOCITY = 1.2
MAX_ANGULAR_VELOCITY = 90.0
No joy. (using LinuxCNC 2.6.5 on Wheezy)
- Topic Author
Kirk_Wallace wrote: Crud, I tried:
[TRAJ]
AXES = 9
[DISPLAY] GEOMETRY not [TRAJ] COORDINATES
- Kirk_Wallace
- Smokeys
- Topic Author
I guess it might be possible have subs for each ASCII code, but I don't know how one would pass the strings to the G-code.
