Parameters
- grey1beard
12 years 11 months ago #40595
by grey1beard
Parameters was created by grey1beard
Is there a way to use an XY position as a parameter ?
For example, is there a way to give the position X[5] Y[10] as #1, and X[6] Y[15] as #2
I presume that #1 = <x[5]y[10]> doesn't work, nor #1 = <x[5]_y[10]> likewise ?
- BigJohnT
- Thank you received: 994
12 years 11 months ago #40599
by BigJohnT
Replied by BigJohnT on topic Parameters
No, you can only pass numbers as a parameter.
What are you trying to do?
JT
JT
- grey1beard
12 years 11 months ago #40610
by grey1beard
Replied by grey1beard on topic Parameters
What I'd like to be able to do is write lines of g code where a particular pair of XY values equated to a single musical note being played by a musical automaton.
For example, if
G01 x[55] y[60]
took the arm to be above the F strings, and
G01 x[55 + #4] y[60 + #5]
took it on to the F#, and
G01 x[55+[12*#4]] y[60+[12*#5]]
sends it up an octave to top F, it would be nice to be able to indicate the value of X for the particular note more compactly in the form of a single parameter.
I can see that I'm trying to get one parameter to indicate two different axis at the same time, so I suspect it's time to draw a line under that train of thought.
J
For example, if
G01 x[55] y[60]
J
- clunc
- Thank you received: 37
12 years 9 months ago - 12 years 9 months ago #42890
by clunc
Replied by clunc on topic Parameters
This is probably nuts, but I'm thinking "Subroutine" or "tines".
Playsub(Xposn,Yposn)
take the arm to Xposn,Yposn
bang it
do something else (maybe call OctaveSub to play an octave higher)
endsub
And the G-code "player" is a sequence of calls to the subroutine(s) with appropriate values of XY.
bang it
endsub
Last edit: 12 years 9 months ago by clunc. Reason: nuts sounds better to my sophisticated eye
- clunc
12 years 9 months ago #42900
by clunc
grey1beard,
I don't have a clear picture, but will throw out a couple of things to maybe make you think in a new direction.
You asked:
> For example, is there a way to give the position X[5] Y[10] as #1, and X[6] Y[15] as #2?
I wonder.
If X and Y were each bounded, and you had enough vars at your disposal, you store both as a single "code" value by some formal; e.g., X[5]Y[10] is stored as 5.1099999 and X[6]Y[15] as 6.1599999, presuming no negative numbers. Negative numbers might be handled by adding a very large number to each first 999990000000000 to each before converting. How about -5.1109999 to represent X[-5]Y[-10]? The problem of saving X[-5.1]Y[-5.1] is left as an exercise to the math professors who are reading this, while looking for help with the CNC machines they built for relaxation. I wonder if "prime numbers" would help... but I diva...
I also stumbled on this in this:
linuxcnc.org/docs/html/gcode/overview.ht...umbered_parameters_a
which refers to what in programming circles is called pointer arithmetic, and indirect pointers.
"Of course, #[1+2] does mean the value found in parameter 3. The # character may be repeated; for example ##2 means the value of the parameter whose index is the (integer) value of parameter 2."
This suggests that it might be possible to create an "indexed" array of say R rows and C columns, stored as a 1-dimensional array, also common with programmers. A single number "index" i refers to a single element of the array; if the index is less than R, it is in the first row: it's position being given by the column its in. So in that case, the i-th element is in Row0,ColC: one number indicates 2.
If i is larger than R, multiples of C are subracted from i (corresponding to the number of rows that have to be traversed, each of length C) before the remainder is a number less than R, after which you know it's the "i-th element of the array refers to the element in ColC of RowR.
So you'd be treating X and Y positions as R and C into an array, computing an I and storing something in #<I>.
Moving to the last bit, about ##2, it's easy for mere mortals to grasp WHAT it is, but hard to conceive how it's to be used. It's an "indirect parameter" which says, "fetch the contents of param #2, and interpret that as the number of ANOTHER parameter and fetch the contents from there to get the value". Right away you can guess that storing non-positive integers or floats would be bad for a ## use, but consider storing the number 5420 in #2, and reading it out and iterating. ##2 would give you the value of whatever's stored in #5420, which happens to be current X, after iterating #2=[#2+1] , the same expression ##2 would now give you the value of Y.
Anyway I hope this helps--even if only to give you some much-need shuteye.
Cheerio,
You asked:
I wonder.
Cheerio,
- newbynobi
- Thank you received: 394
12 years 9 months ago #42908
by newbynobi
Replied by newbynobi on topic Parameters
Why not make a subroutine for every note?
than you would program:
call play_note_c [1] [200] [4]
the parameters in the sub would be
#1 = Oktave to play
#2 = Dwell between repeats
#3 = repeats
so the example will play 4 time the c in the first octave with a delay of 200 ms inbetween each note.
You just have to make subroutines for each note and in everey sub you look for the octave and call a different sub in the sub,
Norbert
#1 = Oktave to play
#3 = repeats
Norbert
