- Thank you received: 83
M66
- billykid
12 years 9 months ago #42931
by billykid
M66 was created by billykid
hi
I'm trying to use the M66 for the signal arcok a small plasma that I am building.
I'm using this: net arc_ok motion.digital-in-00 <= parport.0.pin11-in
with the line P0 L4 M66 Q5 is ok but after 5 seconds without signal movement begins the same.
I tried M66 P0 L0 but it never works, maybe you can use only the options L3 or L4?
thanks in advance
Mauro
thanks in advance
Mauro
- Rick G
- Thank you received: 114
12 years 9 months ago - 12 years 9 months ago #42936
by Rick G
Replied by Rick G on topic M66
Hello,
You need to determine what it will do if there is no output, try something like...
Otherwise it waits then after the waits continues the code.
The result of the M66 is the variable #5399.
Rick G
M66 P0 L3 Q5 (wait up to 5 seconds for digital input 0 to turn on)
O105 IF [ #5399 ne 1]
M5
(debug, No arc transfer)
o106 return
O105 ENDIF
Rick G
Last edit: 12 years 9 months ago by Rick G.
12 years 9 months ago #42937
If you want to end the programme if the timeout happens then maybe this will work
P0 L4 M66 Q5
O100 IF [#5399 LT 0]
(MSG, Timeout!)
M2
O100 ENDIF
Replied by andypugh on topic M66
That is because you have a timeout of 5 seconds.billykid wrote: with the line P0 L4 M66 Q5 is ok but after 5 seconds without signal movement begins the same.
P0 L4 M66 Q5
(MSG, Timeout!)
M2
O100 ENDIF
- billykid
12 years 9 months ago #42939
by billykid
Replied by billykid on topic M66
thanks Rick
I think I will leave it M66 P0 L4 Q20 for example .. time long enough to stop.
I tried it with a button and it works fine
Mauro
Mauro
- billykid
12 years 9 months ago #42940
by billykid
Thanks Andy !
you convinced me to try
Mauro
Mauro
- Rick G
12 years 9 months ago #42959
by Rick G
Glad you got it sorted out.
Rick G
Rick G
Time to create page: 0.496 seconds
