INCREMENTAL THREAD
- mario_rl
12 years 9 months ago - 12 years 8 months ago #43376
by mario_rl
INCREMENTAL THREAD was created by mario_rl
HI,
I NEED TO PERFORM A INCREMENTAL THREAD. NOW I'M PLANNING TO RETROFIT A CNC MILL (HEIDENHAIN TNC155) TO LINUXCNC. WILL BE POSSIBLE TO DO THIS WORK?.
ALSO, I HAVE ANOTHER MACHINE WITH A HEIDENHAIN TNC360, SO IT CAN CONTROL A FOURTH ROTATIONAL AXIS, BUT DON'T KNOW A WAY TO PERFORM THIS TASK.
HAVE ANYBODY EXPERIENCE ABOUT THAT?
THANKS IN ADVANCE, MARIO (AND SORRY FOR THE "WEIRD QUESTIONS"
PD: NOTE THAT IN THE THREAD, THE NOTCH WIDTH IS ALWAYS THE SAME, BUT THE CREST WIDTH IS DECREMENTING.
Last edit: 12 years 8 months ago by mario_rl. Reason: attach image
- ArcEye
- Thank you received: 240
12 years 8 months ago #43396
by ArcEye
Replied by ArcEye on topic INCREMENTAL THREAD
The following user(s) said Thank You: mario_rl
- mario_rl
12 years 8 months ago - 12 years 8 months ago #43482
by mario_rl
Replied by mario_rl on topic INCREMENTAL THREAD
hi, sorry but i tryed to attach a picture and it didn't work.
- ArcEye
12 years 8 months ago #43483
by ArcEye
Should be OK using jpg png or gif under 500K
Give it another try
Give it another try
- mario_rl
12 years 8 months ago #43486
by mario_rl
ok thanks i didn't know about exact limit in attachements, there is a trim... not a complete picture. But in essence, this is a polycarbonathe cylinder with a thread "incremental pitch" milled on it. The aim is to feed bottles in a filling machine so that arrive at a variable speed, but regard to incremental spiral geometry, at the end of the thread, the bottle speed and position is syncronized with the whole filling machine.
Very thanks in advance, Mario.
- ArcEye
12 years 8 months ago #43487
by ArcEye
I see!
It is a bit of a cross between an archimedes screw and a barley twist chair leg. :laugh:
So long as you can accomodate it on your machine, I would imagine it could be cut quite well using a mill with a 4th axis, the main problem would probably be flexing of the material away from the cutter, it would need supporting throughout its length.
What you need however is the G Code to cut the 'thread'
Although you could code it by hand I suspect a CAD / CAM route would be easier.
Time to create page: 0.137 seconds
