How to wait for X seconds in GCODE
11 years 10 months ago #53761 by gaeldk
How to wait for X seconds in GCODE was created by gaeldk
Hello,
When I start my program
I start with the following sequence
G17 G21 G90
G00 X0 Y0 Z9.999 M03
then the rest
How can I wait for 5 seconds after the M03 to be sure that my spindle manages to reach the required speed ? I know that it does so in 5 seconds.
Only the on/off of the spindle is digitally controlled on my setup.
11 years 10 months ago - 11 years 10 months ago #53762 by gaeldk
Replied by gaeldk on topic How to wait for X seconds in GCODE
Considering doing this via an M1xx user defined command linked to a batch like this :
#!/bin/bash # wait for P seconds sleep $1 exit 0
all this in a M101 file...
A bit violent, is there something smarter ?
Last edit: 11 years 10 months ago by gaeldk.
11 years 10 months ago #53763 by ArcEye
Replied by ArcEye on topic How to wait for X seconds in GCODE
Hi
www.linuxcnc.org/docs/devel/html/gcode/gcode.html#sec:G4-Dwell
G4 P5
will do what you want.
I do the same all the time to ensure spindle is up to speed on my lathe before commencing a program
The following user(s) said Thank You: gaeldk
11 years 10 months ago #53764 by gaeldk
Thanks ! So the cause of all this is my poor English...
I was looking for a sleep or wait command, had no idea what dwell meant....
11 years 10 months ago #53766 by ArcEye
I think it is called that because of the typical usage for it, which is to dwell at the bottom of a hole to ensure cut depth
or above a hole to allow swarf clearance etc
The following user(s) said Thank You: FariaAl, bkt
9 years 10 months ago #84416 by clunc
Replied by clunc on topic How to wait for X seconds in GCODE
As a non-daily CNC hobbyist/operator, I have an M0/Pause after M5, w/a (MSG, Paused for spindle to reach speed.)
I find this wait very helpful to compose myself for the havoc my code is about to unleash.
Time to create page: 5.332 seconds
