- Thank you received: 486
G76 Threading cycle
- Clive S
11 years 7 months ago #57219
by Clive S
G76 Threading cycle was created by Clive S
There appear to be several version of the G76 threading cycle.
In the Linux cycle the parameters are P,Z,I,J,K,R,E,L Where P is the pitch and I is the thread peak offset from the drive line
Yet in other versions I have read that P is a 6 digit number and F is the pitch .
Does Linuxcnc use a none standard version.
I am on a steep learning curve and getting confused (probably my age)
This is what I have used to try and cut a 10mm x 1.5mm pitch thread.
G7
G0 X10 Z2
G76 P 1.5 Z-10 I -0.1 J 0.1 R1.0 K 0.92 Q0 H2 L1
G0 Z0
G0 X40
I am touching off at X0 centre and Z0 end of bar.
Am I doing this correct? Do I have the parameters and numbers correct for G7 Dia mode.
Thanks Clive
G7
G0 X10 Z2
G0 Z0
G0 X40
Thanks Clive
- ArcEye
- Thank you received: 240
11 years 7 months ago #57226
by ArcEye
Replied by ArcEye on topic G76 Threading cycle
Hi
Every controller varies, the only thing you should be reading is the documentation for linuxcnc.
I posted this recently for another user, hopefully will be of use to you too.
www.linuxcnc.org/index.php/english/forum...lem-stepconfig#57063
- Clive S
11 years 7 months ago #57227
by Clive S
Thanks. I think you did post this to me in another thread. I found it very useful.
I think it may have dawned on me after I have re read your post. In that Ihave used 0.92 for the K peram. should that have been doubled because we are in G7 Dia mode?
I have been going round in circles reading all the stuff I could find re G76 and getting nowhere.
Clive
Replied by Clive S on topic G76 Threading cycle
ArcEye wrote: Hi
Clive
- ArcEye
11 years 7 months ago #57229
by ArcEye
Should have noticed that, sorry
I always program in diameter mode, since the finished diameter is what you measure, so never really had the confusion regards radius.
If you look at the example I gave, I just used 1.5mm for both P and K, since a metric standard 1.5mm thread is equal in depth and pitch.
So yes, the total depth is 3mm, ie 3mm lesser diameter than the peak of the thread, but the depth of cut is 1.5mm.
Clear as mud!
Basically you program in the dimensions of the thread, not the overall dimensions of the billet with the thread cut into it.
Clear as mud!
- Clive S
11 years 7 months ago #57259
by Clive S
Thank you Sir ArcEye.
I have now successfully cut my first cnc thread 10mm on my little ML-S7 lathe cut the encoder disc on the router Index A & B 64 slot.
With the help on here I have got the hal files sorted etc
It was the dia mode G7 that fooled me the most and the different flavours of G76.
Clive
Clive
- harshal
8 years 3 months ago - 6 years 2 months ago #114664
by harshal
Replied by harshal on topic G76 Threading cycle
www.cncknowledge.in/2018/07/g76-fanuc-th...ith-description.html
N10 M06 T01 01 ;
N20 M04 G97 S1000 ;
N30 G00 X45 Z5 ;
N40 G76 P020060 Q100 R50 ;
N50 G76 X38.7 Z-50 P1227 Q100 F2 ;
N60 G00 X45 Z5 ;
N70 M05 M09 M30 ;
DESCRIPTION OF MAIN PROGRAM :-
N10- Tool change command , select tool no. 1
N20- Spindle ON anti clockwise , constant spindle speed command , speed is 1000 rpm
N30- Rapid action command where X45 and Z5 .
N40- Threading cycle command , P020060
( P02 = No. of finished path
00 = Chamfer amount at end
60 = Angle of tool tip ) ,
Q100 = Each cut is 0.1 mm ,
R20 = finishing allowance 0.02mm
N50- Threading cycle command , Minor dia X axis , threading along Z- axis up to -50 , Threading depth , Depth of finish cut 0.1 mm , pitch is 2 .
: M40X2
Major diameter is 40
Pitch is 2
Thread depth calculation = Pitch x 0.61363
= 2 x 0.61363
= 1.227 mm in micron is 1227
Minor diameter = 40-1.23 = 38.7 mm
N60- Rapid action command where X45 and Z5 .
N70- Spindle off , coolant off , main program end .
for more info visit- www.cncknowledge.in
N10 M06 T01 01 ;
N20 M04 G97 S1000 ;
N30 G00 X45 Z5 ;
N60 G00 X45 Z5 ;
N70 M05 M09 M30 ;
: M40X2
Pitch is 2
= 2 x 0.61363
Last edit: 6 years 2 months ago by harshal. Reason: Minor edit
Time to create page: 0.135 seconds
