set A-axis to 0.0
- jornbyte
11 years 5 months ago #59297
by jornbyte
set A-axis to 0.0 was created by jornbyte
Hello
I want the A-axis to 0.00 provide without it rotates.
Is that a MIDI commando possible?
- BigJohnT
- Thank you received: 994
11 years 4 months ago #59304
by BigJohnT
Replied by BigJohnT on topic set A-axis to 0.0
Have you tried to just re-home the axis... that seems to work in the sim.
JT
JT
- jornbyte
11 years 4 months ago - 11 years 4 months ago #59312
by jornbyte
Replied by jornbyte on topic set A-axis to 0.0
Hello John
the axis rotates, which I want to avoid.
I use a 3D printer LinuxCNC. After a job XYZ be reduced to zero.
The A axis retains its value. When I start a new job it rotates to zero and used filament that should not be. Therefore I'm looking for a solution.
excuse my english I'm from Germany
Jornbyte
Jornbyte
Last edit: 11 years 4 months ago by jornbyte.
- alan_3301
- Thank you received: 22
11 years 4 months ago #59317
by alan_3301
Replied by alan_3301 on topic set A-axis to 0.0
Does the extruder axis have a homing routine? I wouldn't think so.
It should just reset it to 0 without moving.
If you are using the axis GUI click the menu item "machine" then "homing" then "home A axis"
- jornbyte
11 years 4 months ago #59318
by jornbyte
Hello alan_3301
the extruder has no reference switch is why he turns to it again is zero.
- ArcEye
- Thank you received: 240
11 years 4 months ago #59349
by ArcEye
Replied by ArcEye on topic set A-axis to 0.0
If you set the HOME_SEARCH_VEL and HOME_LATCH_VEL etc to 0, it will home without movement and zero the DRO
www.linuxcnc.org/docs/devel/html/config/....html#_configuration
Time to create page: 1.156 seconds
