G-Code Error?
11 years 1 month ago #62068 by Todd Zuercher
G-Code Error? was created by Todd Zuercher
This one has me stumped.
I am having trouble running a file. It loads and displays in the back plot fine. But when running it stops around line 890, setting an alarm "Circular move on line 2968 would exceed joint 8's negative limit." But there isn't a circular move involving joint 8 (the W-axis) on line 2968 or anywhere else in the file that I'm aware of.
The machine I am running this on is a 3-axis router with a second spindle mounted to a W-axis (so technically a 4 axis machine). We use it to do router engraving 2 at a time. The G-code is generated with only XYZ and the W is inserted at load time with a script file.
Running this on 2.7.0-pre7
Attached is the script file and the G-code file.
11 years 1 month ago #62096 by emcPT
Replied by emcPT on topic G-Code Error?
You zip file does not contain the gcode.
What are your machine limits?
11 years 1 month ago - 11 years 1 month ago #62100 by Todd Zuercher
Replied by Todd Zuercher on topic G-Code Error?
Try again. Here is the G-code file
Last edit: 11 years 1 month ago by Todd Zuercher. Reason: trouble attaching file
11 years 1 month ago #62101 by Todd Zuercher
The limits for the Z and W are 0 to -8 inches
The G54 offset is approximately -1.5" for Z and W
No tool offsets are used.
This same code runs fine on a different machine (not running Linuxcnc)
The same design output without arcs runs fine. Limits should not be an issue.
11 years 1 month ago #62114 by andypugh
Replied by andypugh on topic G-Code Error?
If you select "edit" from the Axis menu can you save the final version of the G-code?
It will help a lot to see what actual code is being run.
11 years 1 month ago #62120 by Todd Zuercher
I thought when I tried that only the pre filtered file showed up in gedit the same as what I attached. and is why I included the file filter script.
Time to create page: 0.549 seconds
