Macro
- smplc
9 years 2 months ago #97625
by smplc
Macro was created by smplc
Does LinuxCNC parametric programming have custom macro similar to Fanuc G65, G66, G67 and P, M or G9### and underlays canned cycles? For instance a drill fixed cycle or a roughing cycle with looping and branching. Are any parametric programming algorithms reference sources of a multi-repetitive, non-monotonic and Type 2 cycle (Fanuc G71) without air cuts and not like roughing an existing pattern and casting (G73)? Does LinuxCNC have a parametric programming quick reference key and where?
- Thank you received: 1480
9 years 2 months ago - 9 years 2 months ago #97632
Replied by Todd Zuercher on topic Macro
I am not real familiar with Fanuc macro calls (not all of our Fanuc machines have Custom Macro enabled.) so I don't use them much.
Linuxcnc does not have a Modal call similar to M66. (To the best of my knowledge, but it wouldn't be the first time I was wrong.)
But to the best of my knowledge most of the same functionality as G65 can be achieved with Linuxcnc's O-subs. With one glaring difference. Linuxcnc does not have a goto funtion. You can usually work around this if you're clever in your parametric programming. But it can make porting existing Fanuc code over to Linuxcnc a bit of a pain.
Here is a link to the O-Word section of the Linuxcnc Docs.
linuxcnc.org/docs/html/gcode/o-code.html
And the Parameter section of the G-Code Overview.
linuxcnc.org/docs/html/gcode/overview.html#_parameters
It might be possible to add G65, G66, G67 functionality without too much difficulty using Remapping. G65,G66, and G67 are currently undefined and open for remapping. (I believe someone recently added Fanuc style M98/M99 support this way.)
linuxcnc.org/docs/html/remap/remap.html
Last edit: 9 years 2 months ago by Todd Zuercher.
- smplc
9 years 2 months ago #97638
by smplc
Replied by smplc on topic Macro
LinuxCNC O-Codes similar Fanuc N### (line number). i.e. GOTO 111; N111; G70 P111; DO 111; END 111;
9 years 2 months ago #97643
As far as I know Linuxcnc completely ignores N### line numbering, so it can't be used for referencing a GOTO or other branch/loop fuctions. But you can use the o-word while/endwhile, do/while, if/elseif/else/endif, repeat, and call.
- smplc
9 years 2 months ago #97650
by smplc
Understood. I haven't reference source a parametric algorithm of a canned cycle similar to Type 2 foregoing. I can set a counter to do a non-monotonic profile but it has some air passes yet. It could require some nested loops, branching and arithmetic expressions. I'll have to improvise, experiment and test it simulated.
9 years 2 months ago #97651
Replied by andypugh on topic Macro
G71 / G72, if you mean lathe roughing cycles is a "work in progress".
There is a simple (no pockets) version here:
github.com/LinuxCNC/linuxcnc/tree/BenPotter/G71
And a more complicated (with pockets) one here done as a remap in Python (but it has limitations)
github.com/LinuxCNC/linuxcnc/tree/andypugh/g71type2remap
The remap version could, in theory, be used on a standard install without recompiling.
Time to create page: 0.206 seconds
