- Thank you received: 6
M19 spindle not rotating
- COlger81
- Topic Author
6 years 1 month ago #182907
by COlger81
M19 spindle not rotating was created by COlger81
I have a Hitachi WJ200 spindle drive which is not setup for encoder feedback. Encoder with single pulse index feeds direct to Mesa 7i77 which is setup and will properly rigid tap (coordinated movement). I have set an offfset in INI for orientation but when M19 is commanded, the spindle is not rotating. Assistance would be appreciated.
- 0x2102
- Thank you received: 80
6 years 1 month ago #183201
by 0x2102
Replied by 0x2102 on topic M19 spindle not rotating
Here is an example HAL for M19 (spindle orient).
You will need to adopt it to your hardware.
talla83.homepage.t-online.de/linuxcnc/20...7_spindel-orient.zip
Time to create page: 0.040 seconds
