G28 and G30 don't do xy rotation
  • rgb
  • Topic Author
  • Junior Member
  • Junior Member
5 years 1 month ago #220856 by rgb
At least it looks that way from poking though the code in Interp::convert_savehome() The code appears to remove the g5x, g93 and tool offsets but doesn't do usual xy rotation... Is that a bug?
Thanks,
Bob Bond
5 years 1 month ago #220891 by Aciera
Replied by Aciera on topic G28 and G30 don't do xy rotation
What do you mean by 'doesn't do usual xy rotation'?
Are you expecting G28 and G30 to unrotate a rotation set previously by 'G10 L2 P- <axes R->'?
  • rgb
  • Topic Author
  • Junior Member
  • Junior Member
5 years 1 month ago #220900 by rgb
Replied by rgb on topic G28 and G30 don't do xy rotation
Yes, that's it. The docs say absolute coordinates are saved. I was assuming that you can't get back to absolute coordinates without undoing a possible "R" rotation on x, y.
5 years 1 month ago #220921 by Aciera
Yes, I see your point. I don't have an answer and I've never used it. So maybe wait if somebody else has an explanation.
  • rgb
  • Topic Author
  • Junior Member
  • Junior Member
5 years 1 month ago - 5 years 1 month ago #221208 by rgb
Here's a simple test case:
g20
g10 p1 l2 x0 y0 z0
g10 p2 l2 x0 y0 z0 r45
g55
g0 x1 y1
g28.1
g54
(g0)
g0 z1
(g28)
g28
%executing
And the rs274 output:
1 N..... USE_LENGTH_UNITS(CANON_UNITS_MM)
2 N..... SET_G5X_OFFSET(1, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
3 N..... SET_G92_OFFSET(0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
4 N..... SET_XY_ROTATION(0.0000)
5 N..... SET_FEED_REFERENCE(CANON_XYZ)
6 N..... ON_RESET()
7 N..... USE_LENGTH_UNITS(CANON_UNITS_INCHES)
8 N..... SET_G5X_OFFSET(1, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
9 N..... SET_XY_ROTATION(0.0000)
10 N..... COMMENT("interpreter: setting coordinate system origin")
11 N..... SET_G5X_OFFSET(2, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
12 N..... SET_G92_OFFSET(0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
13 N..... SET_XY_ROTATION(45.0000)
14 N..... STRAIGHT_TRAVERSE(1.0000, 1.0000, 0.0000, 0.0000, 0.0000, 0.0000)
15 N..... SET_G5X_OFFSET(1, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
16 N..... SET_G92_OFFSET(0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000)
17 N..... SET_XY_ROTATION(0.0000)
18 N..... COMMENT("g0")
19 N..... STRAIGHT_TRAVERSE(0.0000, 1.4142, 1.0000, 0.0000, 0.0000, 0.0000)
20 N..... COMMENT("g28")
21 N..... STRAIGHT_TRAVERSE(0.0000, 1.4142, 1.0000, 0.0000, 0.0000, 0.0000)
22 N..... STRAIGHT_TRAVERSE(1.0000, 1.0000, 0.0000, 0.0000, 0.0000, 0.0000)
23 N..... FINISH()
24 N..... ON_RESET()
25 N..... ON_RESET()
It's clear that line 22 is wrong. If the z1 is moved to the g28 command it seems to be fine.
Last edit: 5 years 1 month ago by rgb.
