[Solved]LinuxCNC is rounding corners, doesn't follow the original gcode
4 years 8 months ago - 4 years 8 months ago #235842 by Twizzlermill
Hello all,
I'm not sure whether this is the right subforum; I'm not even usre that this is a LinuxCNC issue and not something I need to solve during CAM, but I figured I need to start somewhere.
I also apologize in advance that this post may be a bit incoherent, this issue is very new to me and I'm still figuring out where exactly the root cause is.
Setup:
I'm running LinuxCNC with a Mesa 7i7i6e card and JMC closed loop steppers. The CAM software I use is FreeCAD (Path job is set to "LinuxCNC" as output method).
Here's the problem:
Yesterday, I was cutting a 35mm block of aluminium, pretty much pushed my machine to the limit of what it is capable of. I'm still very much in the learning phase; most stuff I made so far worked out nicely, but yesterday, I had two issues that were related to the machine not following the gcode path 1:1, but taking shortcuts in the corners. The first one I assume was due to my machine not being calibrated properly. The toobit cut into the edge of the block during an admittedly sketchy 3d surfacing operation:
image missing https://i.imgur.com/p93ZA81.jpg
Last edit: 4 years 8 months ago by Twizzlermill.
4 years 8 months ago #235843 by tommylight
Try using G64 P0.1
where 0.1 is 0.1mm of tolerance from he exact path, so use a value that is suitable to you.
That has to be at the top of the gcode file, although also check if CAM is adding some strange gcode.
The following user(s) said Thank You: Twizzlermill
4 years 8 months ago #235847 by Twizzlermill
Try using G64 P0.1
Thanks, I'll try that.
I don't see any strange gcodes, but maybe I'm missing something. This is the start or the code:
(Exported by FreeCAD) (Post Processor: linuxcnc_post) (Output Time:2022-02-20 16:13:03.348369) (begin preamble) G17 G54 G40 G49 G80 G90 G21 (begin operation: Fixture) (machine units: mm/min) G54 (finish operation: Fixture) (begin operation: 8mm_endmill001) (machine units: mm/min) (8mm_endmill001) M5 M6 T1 G43 H1 M3 S0 (finish operation: 8mm_endmill001) (begin operation: RampEntryDressup) (machine units: mm/min)
Could it maybe have something to do with running a different code earlier? Maybe that some commands were still active and not revoked? Because I ran a different operation right before the pocketing one.
4 years 8 months ago #235850 by tommylight
4 years 8 months ago #235851 by andypugh
4 years 8 months ago #235878 by Twizzlermill
Time to create page: 0.182 seconds
