- Thank you received: 4
G code how to walk joints ??
- EdisonBin
4 years 3 months ago #246624
by EdisonBin
G code how to walk joints ?? was created by EdisonBin
Hello!
I'm a novice, and I've just come into contact with linuxcnc and G code.
I have a problem with G code. I have a 6-axis mechanical arm, and everything is normal.
In MDI mode, I send the following commands to control them, which is very smooth. For example:
c.mdi("G0 X10 Y20 Z15 A5 B3.6 C8.1")
But now I want to use joint mode to control their movement. Is there any joint movement command in G code? For example:
c.mdi("G0 J0.. J1.. J2.. J3.. J4.. J5..")
Can g code meet my requirements? Move in joint position instead of "xyzabc"
Thank you, please be as detailed as possible
- Thank you received: 2177
4 years 3 months ago #246626
linuxcnc.org/docs/devel/html/motion/switchkins.html
This allows you to switch between world- and joint-mode by calling a custom M-Code.
There is a simulation config in version 2.9 with a 6 axis industrial manipulator that should help you: /configs/sim/axis/vismach/melfa-sim
If you want to look at that before you install 2.9:
github.com/LinuxCNC/linuxcnc/tree/master...is/vismach/melfa-sim
I have that same robot here in my shop and it works perfectly. Make sure to read the various comments in the above simulation config.
Replied by Aciera on topic G code how to walk joints ??
If you are using version 2.9 then the answer is yes. The feature is called "switchable kinematics":Can g code meet my requirements? Move in joint position instead of "xyzabc"
- EdisonBin
4 years 3 months ago #246633
by EdisonBin
Replied by EdisonBin on topic G code how to walk joints ??
Hello, Aciera
Thank you very much for answering me in your busy schedule.
I just found that my Linux is version 2.8.2, not 2.9
Does this affect my use of "switchable kinematics"?
I downloaded the file you gave me, put it on the desktop, open it with the terminal, and found an error. Is this caused by version 2.8.2? I put the picture below
Thank you for your answer!
- EdisonBin
4 years 3 months ago #246634
by EdisonBin
Is there only "switchkins" method?
Are there any other methods that have similar effects?
If I want to upgrade to linuxcnc 2.9, what should I do?
Because the official website has only 2.7 and 2.8.
Thank you!
Thank you!
4 years 3 months ago #246647
To actually run the sim config you will need to install version 2.9 (see below) and then you will find the linked config in the config selector to run it.
buildbot.linuxcnc.org/
Or you can get the sourcecode from the github site and build locally on your machine. This can become a somewhat involved process as you might need to manually install packages that linuxcnc depends on (called a RIP install).
What I meant is that you might want to browse the linked simulation config folder to read the various comments. For example how to switch from world to joint mode in G-Code in the "example.ngc" or the M-code remaps (M428, M429) in the folder "remap_subs".I downloaded the file you gave me, put it on the desktop, open it with the terminal, and found an error. Is this caused by version 2.8.2?
Not that I know of.Are there any other methods that have similar effects?
You can install the current development version 2.9 as a deb install:If I want to upgrade to linuxcnc 2.9, what should I do?
- EdisonBin
4 years 3 months ago #246649
by EdisonBin
OK, thank you, my friend.
Now I'll browse the update link you gave, because it's not easy for me.
Is there any essential difference between the 2.8 system and the 2.9 system?
I plan to update the system to 2.9 and copy the whole project I can now run intact to 2.9. This is feasible, isn't it?
Then I will study the "switchkins" method
Time to create page: 5.107 seconds
