- Thank you received: 3
Ok even in Metric and Minimum Resolution =.0001 the error remains.
Files will be much bigger, and will probably run a lot more slowly as the motion planner has a harder time.So is it a handicap without G2 G3 or is it equal?
The X,Y,Z format is set as "Cordinate" "5.3" -> XXXXX,XXX but in my *.ngc there are for e.g. "N0110 X-2.6228 Y2.5496" so one position after decimal point more than specified. Thats some kind of strange
Secondly I don't understand why i should make the values much more precise than my mill could handle?
So do you think the error will be solved if I set the Cordinate Format to 5.4?
