- Thank you received: 4
LinuxCNC is Adding Arc Movements That Do Not Exist In the Program
- reynolds087
- Topic Author
3 years 7 months ago #267445
by reynolds087
Replied by reynolds087 on topic LinuxCNC is Adding Arc Movements That Do Not Exist In the Program
Thanks for confirming. You may have missed my prior response. It seems that an older version of the program was not being updated when I would load it through the file browser. A restart of LinuxCNC fixed my issue.
3 years 7 months ago #267449
Unfortunately, I don't think we can say that it's gone. What you showed in the first post was the track of what LinuxCNC thought actually happened (dark red line).
Once you reload the program it clears that track from the display and shows only the programmed path.
Can you run the program again, cutting air, maybe even without a tool [1] and see if the extra moves happen again. If they do, do a second run and see if they are in _exactly_ the same place.
If they are in the same place, then suspect software, if not then it's probably the real world: electrical noise, pixies, vibration, aliens...)
[1] Some spindles / toolchangers should not be run with no tool, so be careful.
Replied by andypugh on topic LinuxCNC is Adding Arc Movements That Do Not Exist In the Program
I closed Axis and re-opened it and loaded the program and it's gone.
