G64 not read properly in RS247NGC_STARTUP_CODE
2 years 11 months ago #286601 by cmorley
In 2.9 g64 is set by default to a much more reasonable number.
But as Rod mentioned anything can override the setting.
2 years 11 months ago #286607 by piflixe
Oh, I have missed the release of 2.9.1 as stable linuxcnc version. Can't wait to upgrade!
Thanks for the remarks. I will test it once I have upgraded.
However, did anyone test including G64 in the startup code and verified it is actually processed correctly?
2 years 11 months ago #286621 by cmorley
open linuxcnc's status program and look at 'settings', the last two numbers are g64 P and Q numbers
2 years 11 months ago #286639 by radom
remember when you toggle F2 in axis you lose your g64
so having it in startup_code I find it imho useless
2 years 11 months ago #286658 by cmorley
The following user(s) said Thank You: radom
2 years 11 months ago #286670 by piflixe
Dear @radom! Thanks for that remark. If it is the case, then you are absolutely right that adding it in the startup code does not make sense. It could well be the reason why it seems not to work: it might be read in the startup code but then set back do default when enabling the machine.
But I don't understand the reason for this? The startup code is meant to bring the machine into a known and reproducible state, if the settings are overwritten by F2 then there is no point in it. Or is it only true for some commands?
Time to create page: 0.064 seconds
