Difference in Fanuc
- fannlow
- Topic Author
12 years 9 months ago #42594
by fannlow
Difference in Fanuc was created by fannlow
Hi and thanks for the references, its plenty helpful!
need to also know if these linuxCNC "G" & "M" codes are the same we saw over fanuc?
because I'm trying to edit the original or generic fanuc 3x, 4x, 5x in the masterCam X7.
looking over the .pst files that is in existance with the software pack, it seems some of what they are adding to the file is not actually needed by linuxCNC.
that's why I'm asking if anything else is difference or at least that I know what linuxCNC needs and doesn't.
that way, I can edit the post processors to output the correct paths and codes to linuxCNC so I don't have to re-edit or delete out every post I made from masterCam X7.
many many thanks !
many many thanks !
- emcPT
- Thank you received: 95
12 years 9 months ago #42614
by emcPT
Replied by emcPT on topic Difference in Fanuc
There are many differences between the Fanuc code and the Linuxcnc one.
It also depends if you are talking about a milling machine or a lathe, or other.
- fannlow
- Topic Author
12 years 9 months ago - 12 years 9 months ago #42659
by fannlow
Replied by fannlow on topic Difference in Fanuc
it will be on a mill machine.
currently running on 3 axis.
and another mill on 4 axis.
but, if I can use the mastercam x7 generic or fanuc processor then change it to the linuxCNC, it would be easier for me to follow the same format for all the other 4 or 5 axis.
posting the file or format here will also help others in need of finding or editing a post processor much easier.
but am needing to find out what's the main differences, example compensation or "G" numbers being different for other functions?
have tried out the previous EMC2 pp from mastercam v9, but turns out after upgrading it to X7, the linuxCNC has some "O" or "A" letters that are not required, as well as tool table calling and tool number.
hence, I'm thinking of just making it simple to format the pp.
let me know if you need any sample files from mastercam?
I'm uploading the generic and fanuc pp from the mastercam X7 here for references.
am still reading up on the things that was posted, lots of good information on this forum, still referencing them.
Last edit: 12 years 9 months ago by fannlow.
Time to create page: 0.154 seconds
