Help: How to run X and A axis with different feed rates simultaneously?
1 year 11 months ago #314992 by spumco
i want the A axis to be rotating continously at a given feedrate.
and X to perform back and forth motion (based on the material width that i have, so that i can acheive a side-by-side layup of the material) the material parameters are mentioned on the above reply of mine.
Do you want A-axis/spindle rotating at continuous speed?
Or do you want it rotating at a continuous material linear speed? i.e. RPM slows down as the number of layers increases?
The few commercial winding machines I've seen appear to have torque-mode drums and an encoder on the material in-feed.  Think encoder wheel with a tire pressed against the material at the infeed guide.  I believe they are in torque mode to ensure that winding tension is constant regardless of number of wraps.
I don't know all the programming, but the infeed encoder RPM value could be connected to the drum/spindle PID to slow it or speed it up.  And the position value would be used to move the guide shuttle based on a material diameter formula.
Not really G-code stuff, more like PLC stuff.
The following user(s) said Thank You: sk_linuxcnc
1 year 11 months ago - 1 year 11 months ago #314994 by spumco
Another thought...
Infeed guide shuttle direction changes could be handled with simple limit switches, or limit switches tied to a material diameter-dependent offset.
i.e "reverse direction N encoder counts after switch 1 goes HIGH". , and N is a variable based on material diameter and some experimentation.
The guide feedrate should be user-adjustable up or down (slightly) to account for inconsistent winding width due to material & tension variations.  The base feedrate would be set by the nominal diameter, and a user-adjustment made once winding starts to account for flattening/width increases once on the drum.
So the user sets material diameter and desired tension values, and tweaks the feedrate as the first couple of turns start going on the drum.
EDIT:
on second thought...
Guide shuttle base feedrate is set by material diameter, and is adjusted in steps which are based on the infeed encoder.  i.e. for diameter X, when encoder count reaches N, reverse direction.
I realized that the switches (mentioned above) are unnecessary as once you are adjusting feedrate in encoder-based increments, you can switch direction based on the same thing.
Still keep the user-adjustment, but also apply the adjustment value (or a derived value) to the shuttle direction change.
And another thought... a component to check the rate of encoder change.  If the rate changes suddenly between direction changes (new layer), it means the machine just over-wrapped an existing layer and should stop and alert the operator.
Last edit: 1 year 11 months ago by spumco. Reason: Fixed dumb idea
1 year 11 months ago #315018 by timo
One stupid idea:
Just program the rotary axis as y-movement. :-) Then program it as a diagonal move based on the diameter. Basically reverse what the CAM software does when you "wrap a path around a cylinder".
Curious if that would do the trick. (it should)
The following user(s) said Thank You: spumco, sk_linuxcnc
1 year 11 months ago #315021 by sk_linuxcnc
is it doable with G-code though?
1 year 11 months ago - 1 year 11 months ago #315025 by timo
I would guess so, (dangerous half knowledge)
If you use y code instead of a, you can move
G01 x right_end y distance_1st F what_works
G01 x 0 y distance_1st_layer + distance_2nd F what_works
G01 x right_end y distance_1st + distance_2nd + distance_3rd F what_works
etc.
The y distance per layer will become shorter and shorter, as the motor needs to do less revolutions when the spool gets bigger, at the same time the x feed will become faster.
Hope that helps.
p.s. the described way should result in a constant material speed.
On the other hand when you keep the material under tension and move in a Thread-pitch fashion (lathe in threading mode) it should work just as fine. The pitch will be one material diameter per revolution and the material speed will increase when the spool becomes larger.
The speed increase can be counteracted by slowing the spindle speed down.
Last edit: 1 year 11 months ago by timo. Reason: p.s.
1 year 11 months ago #315615 by gitin
If you need to wind a large number of identical coils, it is more profitable to make a winding device.
To do this, you need 1 asynchronous motor, 1 VFD and a tension sensor.
If you need it, I can help you with information.
There are more than 100 we in the company.
A polypropylene tape is wound.
You can do it yourself, it's simple.
If you have a CNC machine, you can use it.
This is translated by Google, if something is wrong, I apologize.
G17 G21 G40 G49 G54 G80 G90 G94
g0
z50 (Z is only for visualization in the simulator, not needed for work)
x0
y0
a0
#1 = 50 (radius of the mandrel mm)
#2 = 300 (length of the tube to be wound mm)
#3 = 100 (material speed mm/s)
#4 = 6.35 (material width mm)
#5 = 0.14 (material thickness mm)
#6 = 150 (number of turns)
#7 = [#6*360] (deg.)
#8 = [#2-#4]
G1 F120
O100 while [ #<_a> Lt #7]
G90
#1 = [#1+#5]
Z #1
G1 F [#4/3.1415/2/#1*#3*60] (speed X mm/min)
G91
O101 while [#<_x> lt #8 and #<_a> Lt #7]
X0.635 A36
O101 ENDWHILE
G90
#1 = [#1+#5]
Z #1
G91
O102 while [#<_x> gt 0 and #<_a> Lt #7]
X-0.635 A36
O102 ENDWHILE
G90
O100 ENDWHILE
G90
M2
The following user(s) said Thank You: Aciera, sk_linuxcnc
Time to create page: 0.387 seconds
