Buffered G-code streaming from Python
- Alfapro
- Topic Author
7 months 2 weeks ago #344396
by Alfapro
Buffered G-code streaming from Python was created by Alfapro
Hi, I’m working with LinuxCNC and trying to control motion from Python , similar to MDI.
The goal is to stream G-code commands dynamically (generated in Python), but still preserve trajectory planner behavior such as:
* continuous motion
* G64 blending (no full stops between segments)
The problem I see is that standard MDI execution appears to process commands one-by-one, so the planner does not have enough future segments to perform blending. This results in stop-and-go motion.
What I would like to achieve is something like:
* sending multiple G-code commands ahead of time (buffered)
* without waiting for each command to complete
* so the trajectory planner can see upcoming segments
Questions:
1. Is there any supported way to stream G-code from Python into a buffer (not strictly MDI) so that G64 still work?
2. Does LinuxCNC provide any interface to feed the interpreter continuously (like a queue or pipe) instead of executing discrete MDI commands?
Any pointers or best practices would be greatly appreciated.
Thanks!
* continuous motion
Questions:
Thanks!
- andrax
- Thank you received: 84
7 months 2 weeks ago #344400
by andrax
Replied by andrax on topic Buffered G-code streaming from Python
Why?
This method was used on older NC machines because there wasn't enough memory. But nowadays, transferring data block by block no longer makes sense.
- Alfapro
- Topic Author
7 months 2 weeks ago #344403
by Alfapro
Replied by Alfapro on topic Buffered G-code streaming from Python
I was planning to write a simple DSL for generating motion.
The idea is to have my own commands and then translate them into G-code. If I don’t want to modify the existing interpreter, the obvious way is to just convert everything into standard G-code but then I’m limited by what G-code can express.
Another idea I had was to keep most of the logic in Python and send something like a stream or batch of motion instructions to LinuxCNC, so it could still handle them with proper blending (G64) and without stopping at every segment.
I realize this sounds a bit hacky, but I’m trying to find a balance between flexibility and still using the built-in trajectory planner instead of reinventing it.
- Thank you received: 2177
7 months 2 weeks ago #344404
That is not correct. Linuxcnc supports stacking (blending) of MDI commands.
Replied by Aciera on topic Buffered G-code streaming from Python
- Alfapro
- Topic Author
7 months 2 weeks ago #344405
by Alfapro
Could someone provide an example of how this works? I’m having trouble understanding how MDI blending is supposed to behave and how to implement it correctly.
- Alfapro
- Topic Author
7 months 2 weeks ago #344461
by Alfapro
So it’s actually possible. For some reason I thought MDI only accepts a single command and then blocks until it’s finished.
I’m working on my bachelor’s thesis about a 6-DOF robotic manipulator, and I’m planning to implement something higher-level than G-code. I assumed I’d first have to fully translate my logic into G-code and then execute it, but now I’m thinking of handling the logic in Python and sending commands directly to LinuxCNC instead.
Thanks for the help!
