if/while ?
  • piasdom
  • piasdom's Avatar Topic Author
  • User is blocked
  • User is blocked
15 Feb 2011 06:53 #7203 by piasdom
if/while ? was created by piasdom
can i use if or while(or something) to set the depth ?
i want to cut at a certain depth(ie. .1") at a time till a finish depth(say .788).
been working on Owords, very fun. i usually cut pockets in aluminum.
thanks for any help !
15 Feb 2011 08:39 #7205 by BigJohnT
Replied by BigJohnT on topic Re:if/while ?
You can use do while but there is no if while
www.linuxcnc.org/docview/html/gcode_main.html#r3_2
15 Feb 2011 08:40 #7207 by andypugh
Replied by andypugh on topic Re:if/while ?
Yes, that is pretty much what the functions are for
#1 = .778
#2 = 0
#3 = 0.01
O100 DO
#2 = [#2 - #3]
G1 Z#2
<G-Code goes here>
O100 WHILE [#2 GT #1]
<finishing pass at Z = #1>
15 Feb 2011 09:07 - 15 Feb 2011 09:09 #7209 by BigJohnT
There are quite a few examples in the subroutines section of the do while loop.
Here is one from the ID subroutine.
o100 while [#<Current-Diameter> lt #<Final_Dia>]
O101 if [#<Current-Diameter> + #<Depth_Cut> lt #<Final_Dia>]
#<Current-Diameter> = [#<Current-Diameter> + #<Depth_Cut>]
O101 else
#<Current-Diameter> = #<Final_Dia>
O101 endif
X#<Current-Diameter>
G1 Z#<Z_EndOfCut> F#<FeedRate>
G0 X[#<Current-Diameter>-0.010]
Z#<Z_StartOfCut>
o100 endwhile
Last edit: 15 Feb 2011 09:09 by BigJohnT.
  • piasdom
  • User is blocked
  • User is blocked
15 Feb 2011 09:17 #7210 by piasdom
Replied by piasdom on topic Re:if/while ?
i've read this but couldn't understand what i was reading.(not a program)
  • piasdom
  • User is blocked
  • User is blocked
15 Feb 2011 09:26 #7211 by piasdom
thanks andypugh, but i can't figure out what goes in the [ ].
i understand #2 = [#2 - #3] equaling -.01, so it would move down .01 each pass(or run of code)?
but no idea what [#2 GT #1].
i'm guessing GT is GoTo. what does the While ? xy or z?
<G-Code goes here> where is the "While" telling Z to do anything ? :)
that D### z. thanks for your help !
#1 = .778
#2 = 0
#3 = 0.01
O100 DO
#2 = [#2 - #3]
G1 Z#2
<G-Code goes here>
15 Feb 2011 09:28 #7212 by BigJohnT
It draws a saw tooth shape.
  • piasdom
  • User is blocked
  • User is blocked
15 Feb 2011 09:32 #7213 by piasdom
Thanks for a better example BigJohnT !
but now you threw in "if" and "lt" (guessing "less than")
i understand that "if "this" is "less than" "that" do something.
but i can't see where it(while) knows to move xy or z.
Thanks again !
O101 else
O101 endif
Z#<Z_StartOfCut>
o100 endwhile
15 Feb 2011 09:37 #7214 by BigJohnT
The [a + c + d] the equation inside of the square brackets is evaluated and the result is returned so,
G0 X[3 + 5]
would send the X axis to X8
15 Feb 2011 09:47 #7215 by BigJohnT
Here is the binary operators like LT
www.linuxcnc.org/docview/html/gcode_over...html#sub:Expressions
The basic syntax of a while loop is:
while test is true
do code between while and endwhile
endwhile
So when the while test evaluates to false jump to the endwhile line. and carry on without executing any code between while and endwhile.
Time to create page: 0.090 seconds
