Read axis position
- piasdom
- Thank you received: 9
22 Apr 2011 19:39 #9266
by piasdom
Replied by piasdom on topic Re:Read axis position
andypugh wrote:
piasdom wrote:
Probably because they both have the same O-number. EMC2 uses the O-number to tell which Do belongs to each While.
so i can't use the same do/while more then once ?
Because you are not saying "offset X by this much" you are saying "offset X so that the current position is this value"
- BigJohnT
- Thank you received: 994
22 Apr 2011 20:13 #9267
by BigJohnT
Replied by BigJohnT on topic Re:Read axis position
The only problem I see is you don't assign #2 back to 0 for the second loop. So being a do then test loop you only get one pass.
I'm not sure if it is required but It is better to use different numbers for your loops.
o100 do
o100 while
o101 do
o101 while
o100 do
o100 while
o101 do
o101 while
- piasdom
22 Apr 2011 21:05 #9269
by piasdom
cool...thanks...didn't think about position.
