Waiting for S.Axes problem
14 years 4 months ago #21092 by andypugh
ArcEye wrote:
These 2 threads are pretty much unresolved and the errors look similar
www.linuxcnc.org/index.php/english/compo...=38&id=20554&limit=6
www.linuxcnc.org/index.php/english/compo...tid=9&id=20485#20535
The symptoms are the same, but the cause is almost certainly different.
This is only going to hit people using the pico-systems ppmc. The two chaps you linked to are using stepper-mm.ini and sim-axis.ini which look like the sample configs. Neither make likely candidates for conversion to a PPMC system, but users do odd things.
I think that you get the "waiting for s.axes" problem any time that the realtime part of a HAL component crashes the realtime thread.
It might be worth adding a diagnostic to check for that cause.
14 years 4 months ago #21109 by jmelson
andypugh wrote:
jmelson wrote:
I went ahead and pushed, seems to be in the v2.5_branch tree, is
this the right place to be putting this?
Yes, that gets it in as a bugfix in 2.5, and it will then get merged into the dev branch in a day or so.
OK, I hope that VNR can test this, as I don't have an old enough board to test it here. But,
the problem was quite obvious, the velocity pin did not get created, and then the encoder
module tried to write a value to it.
I did test it with a USC and a UPC board, and it works fine in both cases, so it didn't
break anything (I think). If the lines were moved to the right place to satisfy C syntax,
I don't see how this code could go wrong.
Jon
14 years 4 months ago - 14 years 4 months ago #21110 by jmelson
Right, and write a much more informative message. Not exactly sure how you detect a crashed
RT module in a thread, but hopefully there is a simple way to do so.
This particular bug did not cause the driver to crash during initialization, which would
cause LinuxCNC to shut down immediately with a slightly more informative message.
It only caused it to crash on the first servo thread execution.
Jon
Last edit: 14 years 4 months ago by jmelson.
14 years 4 months ago #21111 by VNR
Replied by VNR on topic Re:Waiting for S.Axes problem
I'm a little afraid to hack into this and make things worse.
Well, after looking at it a bit, the fix seemed so obvious and simple, that
I instaled the update and it is working OK with my USC card (by the way is an old card Rev 2.2 2005-9-1 Number 0046)
Thanks Jon for the patch.
14 years 4 months ago #21112 by jmelson
Excellent! Thanks so much for FINDING the cause, and then testing the fix!
The board rev # is not the same as the firmware rev #. But, a huge change was
made at the rev 3.0 board going to a newer FPGA chip, so older boards
couldn't accept newer firmware.
Jon
8 years 3 months ago - 8 years 3 months ago #115285 by SINGH
Replied by SINGH on topic Re:Waiting for S.Axes problem
i will run the linuxcnc by commond but i have this error .
so please quide me how to fix it.
File Name: linuxcnc_debug.txt
File Size:91 B
File Name: linuxcnc_print.txt
File Size:707 B
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/shailesh/linuxcnc/configs/sim.axis/axis.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=4845
Last edit: 8 years 3 months ago by SINGH.
Time to create page: 0.063 seconds
