Running Axis remotely with Nomachine's NX v3.5
12 years 5 months ago - 12 years 5 months ago #47047 by kostas
For anyone wanting to run Linuxcnc remotely and get the Axis interface on Windows. I don't know if this information is already written somewhere, but I couldn't find anything about the issue, so here is my method.
I use the free Nomachine's NX client for Windows for years for running X applications on Linux machines and today I wanted to run Linuxcnc on a virtual machine over the Internet in simulation to test something. I tried with NX and Linuxcnc crashed with some error messages
Starting LinuxCNC...
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0xffffffff
Serial number of failed request: 682
Current serial number in output stream: 683
I tried with Xming which I also have handy, but the speed was too slow so I searched a bit and found that the following command does the work for NX:
LIBGL_ALWAYS_INDIRECT=1 linuxcnc
The steps for running Axis remotely are:
Install nxserver, nxnode, nxclient on the Linux machine
Install nx client on the Windows machine
Open nx connection wizard on Windows, enter the session name, host and port on the first screen
press next and choose Unix and custom, press settings and choose "run the console"
Finish the wizard and open the newly created session, enter username/password and connect
At the console that will appear enter the "LIBGL_ALWAYS_INDIRECT=1 linuxcnc" I mentioned earlier and Linuxcnc should run ok
I must also say that I haven't tried with NX version 4 and I can't find the deb binaries for NX 3.5 in Nomachine's site now, they say that this version is no longer supported. But I have the 3.5 binaries for anyone wishing to do this.
Last edit: 12 years 5 months ago by kostas.
2 years 3 months ago #306650 by tjtr33
Hello, I just heard of this software,
Seen it in Youtube video
"Building The 5-Axis CNC Machine in a Small Room: A DIY Journey. (Part12)"
Does the software reduce the RPi's cpu load?
or,
Does the RPi still run X and OpebGL and Axis gui?
(I _think _ nhose are the alternatives )
Thx
TomP
Time to create page: 0.047 seconds
