Spindle Speed Override - incorrect behaviour
7 years 1 month ago - 7 years 1 month ago #145946 by TheChosenOne
I would like to be able to set spindle override values by moving spindle speed override slider between 50% and 140%, so I set following values in .ini file:
MAX_SPINDLE_OVERRIDE = 1.400000 MIN_SPINDLE_OVERRIDE = 0.500000
However when I move slider to its left edge I reach 0% instead of 50%. Is it a bug or what I need to do to fix it?
I use newest version from master branch
Last edit: 7 years 1 month ago by TheChosenOne.
7 years 1 month ago #145962 by pl7i92
in the new system the MIN is not used as for some New featuers you now can stop the spindle with the override
so the min is ignored
THIS gives you a advantige on manuell tool load
7 years 1 month ago #146017 by cmorley
What version did it work in?
It looks like it's not in AXIS in 2.7
Where you using a different screen before?
There is no reason i can see not to have it.
Chris M
7 years 1 month ago #146050 by TheChosenOne
My Axis version is 2.9.0
7 years 1 month ago #146052 by tommylight
Duplicate post deleted as per request.
Thank you.
ASUS ROG Crosshair VIII Impact - AMD X570
7 years 1 month ago #146125 by cmorley
TheChosenOne wrote: My Axis version is 2.9.0
So was it just the docs that made you think this would work?
I looked at linuxcnc 2.6 and AXIS never looked for spindle minimum so I am convinced it never did.
Other screens do.
Maybe I'll look at adding it to AXIS in the future.
Chris M
Time to create page: 0.231 seconds
