Spindle Speed Override - incorrect behaviour
23 Sep 2019 11:54 - 23 Sep 2019 12:23 #145946 by TheChosenOne
Spindle Speed Override - incorrect behaviour was created by TheChosenOne
I would like to be able to set spindle override values by moving spindle speed override slider between 50% and 140%, so I set following values in .ini file:
MAX_SPINDLE_OVERRIDE = 1.400000
MIN_SPINDLE_OVERRIDE = 0.500000
However when I move slider to its left edge I reach 0% instead of 50%. Is it a bug or what I need to do to fix it?
I use newest version from master branch
Last edit: 23 Sep 2019 12:23 by TheChosenOne.
23 Sep 2019 14:21 #145962 by pl7i92
in the new system the MIN is not used as for some New featuers you now can stop the spindle with the override
so the min is ignored
THIS gives you a advantige on manuell tool load
24 Sep 2019 01:55 #146017 by cmorley
Replied by cmorley on topic Spindle Speed Override - incorrect behaviour
What version did it work in?
It looks like it's not in AXIS in 2.7
Where you using a different screen before?
There is no reason i can see not to have it.
Chris M
24 Sep 2019 10:09 #146050 by TheChosenOne
Replied by TheChosenOne on topic Spindle Speed Override - incorrect behaviour
My Axis version is 2.9.0
24 Sep 2019 10:51 #146052 by tommylight
Replied by tommylight on topic Spindle Speed Override - incorrect behaviour
Duplicate post deleted as per request.
Thank you.
25 Sep 2019 02:17 #146125 by cmorley
So was it just the docs that made you think this would work?
I looked at linuxcnc 2.6 and AXIS never looked for spindle minimum so I am convinced it never did.
Other screens do.
Maybe I'll look at adding it to AXIS in the future.
Chris M
25 Sep 2019 06:42 #146132 by pl7i92
the VFD has a option to get minimum Frequency on FOR/REV
so if M3/M4 ocures it will never spinn lower then as CHINA 6000rpm -24000
This is good for milling but not for the Touchoff as i like to use 200rpm to touch
25 Sep 2019 08:15 - 25 Sep 2019 08:16 #146138 by TheChosenOne
Yes, documentation made me think it works that way. I have no reason to override spindle speed to 0 but someone might have, so I think this value should be customizable.
Last edit: 25 Sep 2019 08:16 by TheChosenOne.
Time to create page: 0.367 seconds
